Posted October 19, 201015 yr I got my zed minilith today. online pdf isnt the clearest. looks like I use unputs 1-4 if I run full range to amp or input 5 if I run mono to amp.my question is I have left and right sub output off deck. that means I use left or right to go into #5 input on amp..right?http://www.zedaudiocorp.com/PDF/ZedManual-RGB.pdf
October 19, 201015 yr Author looking at this in my head....I have 2 rca outputs for sub off deck....so do I need to run "Y" splitters off them into inputs 1-4 ? I think that is how I am supposed to do it. cant see what else there would be to do.
October 20, 201015 yr Author I got the rca part figured out. I ran a Y splitter from my left /right sub rca to the mono input of the amp...but now I am confused about the response on wiring the sub. its a dual 2 ohm subhere is what he told me. first part makes sense ...2nd part doesnt...I have the sub wired for a 4ohm load now and its wired bridged at the amp...the amp has 2 sets of terminals for dual coils or 2 subs..Dear Michael,The dual 2 ohm coils can be wired in series = 4 ohm andconnected to the amplifier (200w of power) OR you can parallelthe coils for 2 ohm and again connect to the amplifier (400w)The manual can be downloaded on our website---------- Original Message ----------------------------------From: Michael Zeda <[email protected]>Date: Tue, 19 Oct 2010 11:01:26 -0700 (PDT)>Mr. Mantz>I finally got the mini in and I want to make sure its hooked upcorrectly.> >I have left/right RCA sub outs from the deck. I use a Ysplitter and join the signal and run it into the mono jack onthe amp. yes?> >Now other question. I have a dual 2 ohm sub. I have it wiredto a final 4ohm load and 1 set of wires from the terminal of thebox.> >would I get more power if I ran 1 set per coil off the sub toeach terminal of the mini? would the amp see 2 ohm or does itinternally change the load?> >I do not want to damage the amp nor run @ 1ohm> >that is the reason for the elementary questions. I want ithooked up right. I am not used to all these options> >sincerley appreciate the help. nice amp btw.>
October 20, 201015 yr Author thats what I was trying to find out but he finally replied and said he made a mistake and that it couldnt be wired to 2 ohms.
