Does DC Power Engineering have a ho alt for my 2008 Hyundai Elantra?
Thanks
Should I just call?
Should I just call?
probably your best bet
I Think we have one set of cases that we can do either a 180 or 320 with, but unless your running a ton of power (3k plus) the 180 will do just fine.. Your car only has a 70 amper stock, so you can get away with a much smaller alternator than a lot of vehicles with say a 150 amp stock.. We do have XPs coming for this as well, but it is going to be after SEMA.. Rob
Great, I am going to get a hold of you this afternoon!
Sounds great! Dave and Kyle are both out of the office for a bit, and i have to run some errands so if you call in the next little bit, hit me up on my cell.. 801-618-9586 Rob
Thanks Rob, I will call around 2!
Hi Rob. I did not get an email invoice from you. Is everything up and up with my order?
Thanks,
Eric
