October 30, 201016 yr 8 gauge is way too large for speaker 12-14 gauge wire should be more than enough
October 30, 201016 yr Author 8 gauge is way too large for speaker 12-14 gauge wire should be more than enoughI was referring to power/ground wires. Speaker cable will most likely be 12 gauge.Also, I forgot to mention, when I installed my speakers, I had to remove the rubber from the magnet (comes off easily tho). Could that be causing any negative impact on the speaker performance? Had to remove it cause it would not fit all the way in with it.
November 13, 201015 yr Find a 4ch and bridge it. I always buy 4ch amps. Way more flexibility in the long run and usually less expensive for the power you get.One thing about midbass, from my experience is it takes power to make it come to life.
