November 3, 201016 yr Wow, tripple baffle!!! Is there a reason/trick for building the enclosure and then cutting out the port or is that not a normal practice?? Looks Great!!
November 3, 201016 yr Author Wow, tripple baffle!!! Is there a reason/trick for building the enclosure and then cutting out the port or is that not a normal practice?? Looks Great!! Just how we put them together and then we flush trim the port out with a router. Andrew
November 3, 201016 yr Wow, tripple baffle!!! Is there a reason/trick for building the enclosure and then cutting out the port or is that not a normal practice?? Looks Great!! Just how we put them together and then we flush trim the port out with a router. AndrewGuess I just never noticed that before on previous enclosures I've seen you build(always learning something). Thanks for the info!!!!
November 9, 201015 yr AndrewMan that looks great.You guys done an awesome.I'm actually looking for a suv so i may be getting u guys to build me another box,probally 4 15's.Again,great job.
