Posted October 31, 201016 yr From what the coil on db drive wd12 approaches? spiders, cone?What sizes ID, OD, WW at the coil?What recone can approach, if I alter sub in 18inch?
October 31, 201016 yr Author At me steam of the broken speakers and I want them to make! I want to make custom sub!
November 1, 201016 yr Author Parameters voice are necessary to me, ID:?", OD:?", WH:?", FH:?" ??? Where they can be found?Simply mine sub outwardly copy DB, I will assort and measure him, whether the sizes are necessary that the nobility precisely will approach recone from DB!!! Edited November 1, 201016 yr by orenspl
November 1, 201016 yr Fucking useless response. The man clearly isn't from somewhere where English is the first language. Get in touch with db Drive OP, they can help.
November 3, 201016 yr Also look at PSI, they somewhat custom make their speakers. If you have certain build parameters you have to have PSI might be able to accommodate you.
November 3, 201016 yr Also look at PSI Fi, they somewhat custom make their speakers. If you have certain build parameters you have to have PSI Fi might be able to accommodate you.Fixed for you.
November 3, 201016 yr Also look at PSI Fi, they somewhat custom make their speakers. If you have certain build parameters you have to have PSI Fi might be able to accommodate you.Fixed for you.You do not like PSI?
November 3, 201016 yr Also look at PSI Fi, they somewhat custom make their speakers. If you have certain build parameters you have to have PSI Fi might be able to accommodate you.Fixed for you.You do not like PSI?Way too many people do, let's not clog up this thread though. Sorry OP.
