Posted November 1, 201015 yr Hi guys,I was looking at the cut sheets for the fi Q 12 ported which is tunes to 32 Hz, and have a few question.what would I have to do, (if it can be done) to the same box, to tune it to 28 Hz? Or Would I have to build another box?Would you recommend tuning it to 28 Hz as opposed to 32 Hz ? What are the prows and cons?Thanks,Shopvac
November 1, 201015 yr You would need to increase port length to lower tuning, do you feel there is anything lacking with your current enclosure?
November 1, 201015 yr Benefit is pretty non-existent, but of course you didn't state any goals so applying anything to your specific install is impossible for us.
November 1, 201015 yr You'll likely never hear a difference..BTW Sean I emailed you about that crossover...do you still want to get rid of it?
November 1, 201015 yr You'll likely never hear a difference..BTW Sean I emailed you about that crossover...do you still want to get rid of it?Just saw that today and replied, sorry about the delay...and sure
November 4, 201015 yr Author You would need to increase port length to lower tuning, do you feel there is anything lacking with your current enclosure?Have not build the enclosure as yet, I am just trying to understand this whole tuning senario...Thanks,shopvac
November 4, 201015 yr Author No goals specifically, been reading on other forums, with all sorts of suggestions, just would like to build the right enclosure.Sorry for not giving much details, the box is for daily use.Big thanks to everyone for their attentive reply.shopvac Edited November 4, 201015 yr by Shopvac
November 4, 201014 yr No goals specifically, been reading on other forums, with all sorts of suggestions, just would like to build the right enclosure.If you have no goals why even bother with a sub. You can listen to music daily on the stock stereo so that doesn't help...
