Posted November 1, 201016 yr Im hookinh up my BL that I got back in 2008, what Sundown amp do you guy recommend? SAZ-1000d SAZ-1200d SAZ-1500d or SAZ-2000d? thanks
November 1, 201016 yr Either one will be fine the 2000d might be pushing the subs to the limit if you wired it to 1ohm. What's the ohm load on the sub dual 2 or 1 that helps alot on what ohms you can wire it in??
November 1, 201016 yr The one you can afford! All great choices, the new SAX-1200D would be a perfect match!
November 1, 201016 yr Author Either one will be fine the 2000d might be pushing the subs to the limit if you wired it to 1ohm. What's the ohm load on the sub dual 2 or 1 that helps alot on what ohms you can wire it in??its a dual 2
