Im hookinh up my BL that I got back in 2008, what Sundown amp do you guy recommend? SAZ-1000d SAZ-1200d SAZ-1500d or SAZ-2000d? thanks
Either one will be fine the 2000d might be pushing the subs to the limit if you wired it to 1ohm. What's the ohm load on the sub dual 2 or 1 that helps alot on what ohms you can wire it in??
The one you can afford! All great choices, the new SAX-1200D would be a perfect match!
its a dual 2
