Posted November 2, 201015 yr i got a BL 18 with dual 1s and might be getting a sundown sax-1200D so do you think running it at .35 ohms is safe?
November 2, 201015 yr It is not safe at all on a stock electrical.. And that's Dcr... Your actual impedance is 1 ohm. You will have to run it at 2 ohms or void the sundowns' warranty. You should look into a kicker zx1500 since it does 1500 watts at 2 ohms for a resonable price. If you have sufficient electrical you could run it half an ohm, but I don't know how the 1200's handle half ohm loads. Youll be Better off with the kicker amp
November 2, 201015 yr Author It is not safe at all on a stock electrical.. And that's Dcr... Your actual impedance is 1 ohm. You will have to run it at 2 ohms or void the sundowns' warranty. You should look into a kicker zx1500 since it does 1500 watts at 2 ohms for a resonable price. If you have sufficient electrical you could run it half an ohm, but I don't know how the 1200's handle half ohm loads. Youll be Better off with the kicker ampwell i have the big 3 upgrade with all 0 ga and when i get the new amp ill be replacing my 4 ga that i have running to my amp in the trunk with all 0 ga
November 2, 201015 yr Author It is not safe at all on a stock electrical.. And that's Dcr... Your actual impedance is 1 ohm. You will have to run it at 2 ohms or void the sundowns' warranty. You should look into a kicker zx1500 since it does 1500 watts at 2 ohms for a resonable price. If you have sufficient electrical you could run it half an ohm, but I don't know how the 1200's handle half ohm loads. Youll be Better off with the kicker ampbut do you think i should go with a sundown sax-1200D, saz-1500D or maybe even a audioque 2200D?
November 2, 201015 yr It is not safe at all on a stock electrical.. And that's Dcr... Your actual impedance is 1 ohm. You will have to run it at 2 ohms or void the sundowns' warranty. You should look into a kicker zx1500 since it does 1500 watts at 2 ohms for a resonable price. If you have sufficient electrical you could run it half an ohm, but I don't know how the 1200's handle half ohm loads. Youll be Better off with the kicker ampwell i have the big 3 upgrade with all 0 ga and when i get the new amp ill be replacing my 4 ga that i have running to my amp in the trunk with all 0 gaThe big 3 helps the flow of power from A to B, it doesn't however add power. So you still have a stock electrical.Due to your drivers dcr, you can either wire it to 0.5 or 2ohms. 0.5 is a bad choice unless you know what your doing, and you clearly do not or you wouldn't be asking.I'm assuming this is your daily vehicle, playing music, etc. So your gonna want to wire it to 2ohms. As several have stated, look for an amp that makes 1000-1500watts at 2ohms. If you do get the kicker zx1500, your going to need an inline ssf (check out fmods).
November 2, 201015 yr Author It is not safe at all on a stock electrical.. And that's Dcr... Your actual impedance is 1 ohm. You will have to run it at 2 ohms or void the sundowns' warranty. You should look into a kicker zx1500 since it does 1500 watts at 2 ohms for a resonable price. If you have sufficient electrical you could run it half an ohm, but I don't know how the 1200's handle half ohm loads. Youll be Better off with the kicker ampwell i have the big 3 upgrade with all 0 ga and when i get the new amp ill be replacing my 4 ga that i have running to my amp in the trunk with all 0 gaThe big 3 helps the flow of power from A to B, it doesn't however add power. So you still have a stock electrical.Due to your drivers dcr, you can either wire it to 0.5 or 2ohms. 0.5 is a bad choice unless you know what your doing, and you clearly do not or you wouldn't be asking.I'm assuming this is your daily vehicle, playing music, etc. So your gonna want to wire it to 2ohms. As several have stated, look for an amp that makes 1000-1500watts at 2ohms. If you do get the kicker zx1500, your going to need an inline ssf (check out fmods).alright yeah ill consider getting that kicker its a pretty reasonable price but are there any other good brands of amps thatll fit my situation like Rockford or hifonics?
November 2, 201015 yr Buy four 16V batts and two aftermarket alts with a MLA or other VCM capable of boosting alt performance up to 15.8V minimum and then you have a shot. Sundown used to warranty their amps down as they assumed ppl knew what they were doing until they realized ppl were running them at 12V on stock everything. You gotta know what ur doing, and don't stretch it if you can't afford to constantly buy new amps and woofers. Just find a happy medium, and be happy you can save some moolah
November 2, 201015 yr It is not safe at all on a stock electrical.. And that's Dcr... Your actual impedance is 1 ohm. You will have to run it at 2 ohms or void the sundowns' warranty. You should look into a kicker zx1500 since it does 1500 watts at 2 ohms for a resonable price. If you have sufficient electrical you could run it half an ohm, but I don't know how the 1200's handle half ohm loads. Youll be Better off with the kicker ampwell i have the big 3 upgrade with all 0 ga and when i get the new amp ill be replacing my 4 ga that i have running to my amp in the trunk with all 0 gaThe big 3 helps the flow of power from A to B, it doesn't however add power. So you still have a stock electrical.Due to your drivers dcr, you can either wire it to 0.5 or 2ohms. 0.5 is a bad choice unless you know what your doing, and you clearly do not or you wouldn't be asking.I'm assuming this is your daily vehicle, playing music, etc. So your gonna want to wire it to 2ohms. As several have stated, look for an amp that makes 1000-1500watts at 2ohms. If you do get the kicker zx1500, your going to need an inline ssf (check out fmods).alright yeah ill consider getting that kicker its a pretty reasonable price but are there any other good brands of amps thatll fit my situation like Rockford or hifonics?Buy an MB Quart dsc2000.1 and run it at 2 ohms for a cheap ($300) clean grand worth of watts. I've installed over a dozen of these amps, they work just fine with great THD and a 1000 watts+ verified. I'm sure I got one laying around I've clamped them before and gotten over 1000 even at the 50 Hz range, ill go clamp one tomorrow at work and post the pic if you want proof.Or buy two reasonable (500-1000 watt) amps and strap em for that power/impedance combo Edited November 2, 201015 yr by SubSam
November 2, 201015 yr Author It is not safe at all on a stock electrical.. And that's Dcr... Your actual impedance is 1 ohm. You will have to run it at 2 ohms or void the sundowns' warranty. You should look into a kicker zx1500 since it does 1500 watts at 2 ohms for a resonable price. If you have sufficient electrical you could run it half an ohm, but I don't know how the 1200's handle half ohm loads. Youll be Better off with the kicker ampwell i have the big 3 upgrade with all 0 ga and when i get the new amp ill be replacing my 4 ga that i have running to my amp in the trunk with all 0 gaThe big 3 helps the flow of power from A to B, it doesn't however add power. So you still have a stock electrical.Due to your drivers dcr, you can either wire it to 0.5 or 2ohms. 0.5 is a bad choice unless you know what your doing, and you clearly do not or you wouldn't be asking.I'm assuming this is your daily vehicle, playing music, etc. So your gonna want to wire it to 2ohms. As several have stated, look for an amp that makes 1000-1500watts at 2ohms. If you do get the kicker zx1500, your going to need an inline ssf (check out fmods).alright yeah ill consider getting that kicker its a pretty reasonable price but are there any other good brands of amps thatll fit my situation like Rockford or hifonics?Buy an MB Quart dsc2000.1 and run it at 2 ohms for a cheap ($300) clean grand worth of watts. I've installed over a dozen of these amps, they work just fine with great THD and a 1000 watts+ verified. I'm sure I got one laying around I've clamped them before and gotten over 1000 even at the 50 Hz range, ill go clamp one tomorrow at work and post the pic if you want proof.Or buy two reasonable (500-1000 watt) amps and strap em for that power/impedance comboalright ill check that out but how big of an alt would should i look into?
November 3, 201015 yr Biggest you can afford! Voltage drop is the enemy; for the sake of the longevity of your amplifier and speakers the more charging power/reserve power you have the better.
November 3, 201015 yr Buy four 16V batts and two aftermarket alts with a MLA or other VCM capable of boosting alt performance up to 15.8V minimum and then you have a shot. Sundown used to warranty their amps down as they assumed ppl knew what they were doing until they realized ppl were running them at 12V on stock everything. You gotta know what ur doing, and don't stretch it if you can't afford to constantly buy new amps and woofers. Just find a happy medium, and be happy you can save some moolahShit, I ran mine on 12v at .4ohm and I'm doing the same with my db Drive's now.
November 3, 201015 yr Buy four 16V batts and two aftermarket alts with a MLA or other VCM capable of boosting alt performance up to 15.8V minimum and then you have a shot. Sundown used to warranty their amps down as they assumed ppl knew what they were doing until they realized ppl were running them at 12V on stock everything. You gotta know what ur doing, and don't stretch it if you can't afford to constantly buy new amps and woofers. Just find a happy medium, and be happy you can save some moolahShit, I ran mine on 12v at .4ohm and I'm doing the same with my db Drive's now.Yea I exaggerated a bit, mostly for the point that he would only be spending more money for electrical support. I try to encourage ppl to try and work within their reasonable limits, but its ultimately not my choice to make I know
November 3, 201015 yr Buy four 16V batts and two aftermarket alts with a MLA or other VCM capable of boosting alt performance up to 15.8V minimum and then you have a shot. Sundown used to warranty their amps down as they assumed ppl knew what they were doing until they realized ppl were running them at 12V on stock everything. You gotta know what ur doing, and don't stretch it if you can't afford to constantly buy new amps and woofers. Just find a happy medium, and be happy you can save some moolahso much wrong with this.
November 3, 201015 yr Nothing wrong with overkill, especially with an electrical system.x2more electricity =
