Posted November 10, 201014 yr Hey I have a 12" fi bl and I need to recone it I have it all striped down and the basket I sanded all that crap off but I need some advice on how to recone the sub and what I should do thanks for your help Edited November 10, 201014 yr by JRAC
November 10, 201014 yr Old reconing thread that might help...http://www.caraudio.com/forums/subwoofers/156059-reconing-you-w-mr-jizm-man-ehron-v-ngs-custom-woofage.htmlRecone kits can be ordered off the site under the recones tab.Thanks,Scott
November 10, 201014 yr Author Old reconing thread that might help...http://www.caraudio.com/forums/subwoofers/156059-reconing-you-w-mr-jizm-man-ehron-v-ngs-custom-woofage.htmlRecone kits can be ordered off the site under the recones tab.Thanks,Scottthanks that helped alot but does anyone else know if fi send you the glue to mount all of the stuff back together and if they dont where can i order it or what will work to glue it together? thanks
November 10, 201014 yr Author I removed your duplicate thread.lol thanks i posted it via droid so i didnt think it worked the first time
November 11, 201014 yr Old reconing thread that might help...http://www.caraudio....om-woofage.htmlRecone kits can be ordered off the site under the recones tab.Thanks,Scottthanks that helped alot but does anyone else know if fi send you the glue to mount all of the stuff back together and if they dont where can i order it or what will work to glue it together? thanksI believe UPS didn't like Fi sending glue with them, a 5-minute epoxy form a hobby shop will work well.
November 11, 201014 yr Author Old reconing thread that might help...http://www.caraudio....om-woofage.htmlRecone kits can be ordered off the site under the recones tab.Thanks,Scottthanks that helped alot but does anyone else know if fi send you the glue to mount all of the stuff back together and if they dont where can i order it or what will work to glue it together? thanksI believe UPS didn't like Fi sending glue with them, a 5-minute epoxy form a hobby shop will work well.Ok and how much pressure would I need to keep on the spider and cone?
November 11, 201014 yr for a first i recommend 15 minute epoxy....because you can move the sub and everything around if it is not in place.
November 11, 201014 yr You can get a glue kit from us in the accessories section...I'd highly suggest using 15 minute epoxy on your first recone though. It gives you way more room for error.
November 18, 201014 yr Author You can get a glue kit from us in the accessories section...I'd highly suggest using 15 minute epoxy on your first recone though. It gives you way more room for error.thanks everyone for the help when i get my cone in i will post some pics and see if i need to do anything else to the magent before i put my cone on and i think i might get a 15" instead of the 12" because i got a new car and i can fit a big enough box
November 19, 201014 yr Author how do you get that black stuff off the screws and then what is it so i can put it back on? so the screws dont move. thanks alot.. i also have pics just in case im not clearly stating what i was talking about please help Edited November 19, 201014 yr by JRAC
November 19, 201014 yr how do you get that black stuff off the screws and then what is it so i can put it back on? so the screws dont move. thanks alot.. i also have pics just in case im not clearly stating what i was talking about please helpi would use an impact screwdriver, that's what iv seen allot of people use to get those screws lose
November 19, 201014 yr Author how do you get that black stuff off the screws and then what is it so i can put it back on? so the screws dont move. thanks alot.. i also have pics just in case im not clearly stating what i was talking about please helpi would use an impact screwdriver, that's what iv seen allot of people use to get those screws losethere some kind of black glue or something so the screws dont vibrate loose what is it so i can replace it thanks Edited November 19, 201014 yr by JRAC
November 19, 201014 yr how do you get that black stuff off the screws and then what is it so i can put it back on? so the screws dont move. thanks alot.. i also have pics just in case im not clearly stating what i was talking about please helpi would use an impact screwdriver, that's what iv seen allot of people use to get those screws losethere some kind of black glue or something so the screws dont vibrate loose what is it so i can replace it thanksMost Likely ca glue
November 19, 201014 yr Author how do you get that black stuff off the screws and then what is it so i can put it back on? so the screws dont move. thanks alot.. i also have pics just in case im not clearly stating what i was talking about please helpi would use an impact screwdriver, that's what iv seen allot of people use to get those screws losethere some kind of black glue or something so the screws dont vibrate loose what is it so i can replace it thanksMost Likely ca glueso could i just replace it with epoxy, the same kind im going to use for the recone?
November 19, 201014 yr Im sure that would use, I normally use locktite I havnt had a problem using it for years.
