so i have decided on getting the sundown 2500 to run a pair of fi q15's and i had some questions about the electrical needed to support this. i was looking at getting a delco alternator that puts out 220 amps max and 110 amps idle, stock is a 110 max, a kinetik 2400 in the back and 0 ga wire for power, ground and big 3. you guys think this will be sufficient? also would a 250 amp fuse be ok, or should i go with a 300 amp fuse?
Edited by wafsman
That sounds good I would use the 250amp fuse.
Either the 250 or 300 amp fuse will suffice.
What battery do you have under the hood? I would replace the one under the hood as well. Sounds like your on the right track though!
thanks for the feedback everyone. battery under the hood is stock.
250 fuse is fine -- solid plan.
