November 2, 200521 yr that will work for a 10 or a 12....if it "sounds" too small after install, polyfill!wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
November 2, 200521 yr Author okie dokie sounds good i have very little wood to work with and i wanna hear this mofo
November 3, 200521 yr If you invert it you can squeeze that extra little bit out of the enclosure.No massive magnet hogging all the spaces
November 3, 200521 yr i suck....i cant cut worth crap. i need your saw supa!<{POST_SNAPBACK}>Go to Elias' november 11th or 13th
November 4, 200521 yr i suck....i cant cut worth crap. i need your saw supa!If it is a normal box, you can have Home Depot cut your mdf for you. I did that for a few boxes that "I" built for others. Just sent them to the HD with dimensions, they stopped over I bolted them together, routed the speaker hole, glued on fabric and wham--box in 30 minutes. At the one near my house, the first 6 cuts are free the rest are a $0.25 each. Means you have to buy new MDF for each box, but it was cheaper than the saw.Actually I still have them do some cutting as I bought a garage sale radial arm saw instead of a table saw (I hate friggin table saws not only do you occasionally screw something up I swear it feels like you are going to cut your fingers off when you use 'em). Since the radial only does like 30" cuts I have them cut the pieces into manageable size, plus who really likes to cut 4'x8' pieces, they are heavy and akward!
November 5, 200521 yr Author i suck....i cant cut worth crap. i need your saw supa!<{POST_SNAPBACK}>If it is a normal box, you can have Home Depot cut your mdf for you. I did that for a few boxes that "I" built for others. Just sent them to the HD with dimensions, they stopped over I bolted them together, routed the speaker hole, glued on fabric and wham--box in 30 minutes. At the one near my house, the first 6 cuts are free the rest are a $0.25 each. Means you have to buy new MDF for each box, but it was cheaper than the saw.Actually I still have them do some cutting as I bought a garage sale radial arm saw instead of a table saw (I hate friggin table saws not only do you occasionally screw something up I swear it feels like you are going to cut your fingers off when you use 'em). Since the radial only does like 30" cuts I have them cut the pieces into manageable size, plus who really likes to cut 4'x8' pieces, they are heavy and akward!<{POST_SNAPBACK}>really? sux man.. i went over there last week to buy some wood, the guysaid hes only allowd to do 5 cuts. stoopid liar he is...
