Posted January 11, 201114 yr DO NOT PUT IB3S IN SEALED OR PORTED BOXES! I have 128 cbic feet per tower, 60 cubes per subTHX RidinLoudProd my addiction bass mix dont put IB3s in sealed or ported THX RidinLoudProd neighborhood boys Brotha Lynch Hung BASS dont put IB3s in sealed or ported THX RidinLoudProd oxy cotton bass mix dont put IB3s in sealed or ported THX RidinLoudProd posse on vernor bass mix dont put IB3s in sealed or ported
January 11, 201114 yr Author THX RidinLoudProd push em off bass mix dont put IB3s in sealed or ported THX RidinLoudProd suck a nigga dick bass mix dont put IB3s in sealed or ported WOTWs street breakup one(again)
January 11, 201114 yr Author WOTWs street breakup to pod emerges THX RidinLoudProd lil scrappy no problem bass dont put IB3s in sealed or ported
January 11, 201114 yr Author Nothing Else Matters dont put IB3s in sealed and ported boxes check out Blue Print Audio
January 11, 201114 yr Author RidinLoudProd does it again Nothing Else Matters dont put IB3s in sealed and ported boxes check out Blue Print Audio
March 22, 201114 yr Author 5dB increments to see compression starting at -40dB ending at -10dB master volume. Yup, thats a 130dB peak Yup, thats solider than solid a 10Hz, yup, look at that 6Hz 15Hz on upDC on up ;)
March 22, 201114 yr You are very passionate about your audio hobby All you need now is some rotary woofers
March 24, 201114 yr Author You are very passionate about your audio hobby All you need now is some rotary woofers Ive already got plaster separating from lathe, false sealing cracking, and had to put my ceiling fan back up once... if I had even one rotary, my house would most assuredly come DOWN! lol
March 24, 201114 yr Author crossover 80hz vs 250hzfun10Hz -3.6dB FSTHD: 7.70% THD+N: 7.75%2nd: 5.74% 3rd: 5.11%4th: .339% 5th:.3636th: .228 7th: .1298th: .032 9th: .0258124.4dB
March 25, 201114 yr Wow looks great, how big is the the T.V.? (*for size reference) The enclosure makes it look tiny Edited March 25, 201114 yr by reelfish92
March 27, 201114 yr Author Wow looks great, how big is the the T.V.? (*for size reference) The enclosure makes it look tiny lol I get that a lot... it's a 42" the room is 12' wide, each box is 4' wide, leaving 4' between the towers. TV is plenty big for me, but for those that like 60"+ I suppose it won't do Nice sig, now I understand Neo... my new subs are *only* 56lbs.... I couldn't imagine over 70lbs of sub! :-O
