The specialist got back. They said its an audiocontrol and its 75per hour. Fuck that
  • Replies 366
  • Views 28.9k
  • Pulled off door panel, did another layer of resin and mat. Tomorrow lots of sanding and bondo!
  • CrazyKenKid
    CrazyKenKid
    hey no worries man! any time I can help out no problem! it is funny though how it was almost 3db differences from the TL vs the Makeitlouder meter. because when I was using it was always +/- 0.75db o
  • Not sure how to calibrate it And my dmm certainly isn't fancy, but I figured if it's reading a constant voltage then it's probably working Perhaps because we're at different altitudes and climates?
Damn yeah 75 an hour for an inaccurate score, I'll pass. Excursion looks sick!
Good thing I still have Kens meter coming :woot:
Another update:
I've read and seen a bunch of different views on measuring an amplifiers voltage and amperage using dmms and clamps to find wattage. I've read people argue that it's not accurate, or real world, or that you won't see that much power on music, etc.
So take the following for what ever it's worth. I just wanted a rough estimate to see how much power at MAXIMUM the xcons could possibly be receiving.
So I of course played a constant 40hz tone, (obviously music is going to be varying 24/7 unlike a tone, but this will show me the AT MOST possibility).
I got 71v & 18.5a = 1313w before vehicle voltage started approaching 11.9v
So I guess it's safe to assume that once I have a proper electrical system, that the xcons should get a fair amount louder on the saz3000d. :ughdunno:
I would think so, might even be an audible difference. That box looks great. :fing34:
It should be, and by audible, well it's more of being felt that I care about.
But those numbers were with the hu at volume 20. At volume 18 I got a little under 1267watts and though it may not have been that big of a difference by ear, it was certainly felt.
And again these numbers may be off a little since I don't know how accurate my dmm and clamp meter are. But it does give me faith that the amp still has a fair amount more power before clipping :D
And yes I understand that statement suggests the between volume 18 and volume 20 there is only a 46watt difference. Maybe my meters are fucked up or something Idk. All I know is you can feel the difference and those are the numbers I got from the dmm and clamp.
Hope I can break 150 with alt!
Another update:
Yikes, what is your impedence at 40hz?
Another update:
Almost 4ohms, impedance is highest at peak. My vehicle peaks around 39-40hz so thats also why it's higher.
So for those that don't know, CrazyKenKid lent me his hyperdynamics meter (make it louder) so I could do some testing :drink40:
(I hope this doesn't get everyone and their neighbor PMing him though... Getting it here was a pain, USPS lost track of it, said it was at one office then another, then on route, then no idea. Finally got it though!)
I've read that these meters are fairly accurate to a TL, how accurate? Not sure, guessing within a db or two (at least in the range I'm playing around in).
So take it for whatever it's worth...
Mounted mic on left side of windshield, vehicle sealed up.
36hz 147.75db
Didn't write down the other sealed up results because my voltage was dropping after each run, so the scores couldn't be consistent.
Mounted mic on left side of windshield, passenger window down.
36hz 148.76db
38hz 149.66db
Voltage drop was pretty bad, low 12s, and high 11s for a few seconds.
Going to charge the batteries and do a couple more runs tomorrow, perhaps I can get it a tad higher.
TL results are in...
Mic at headrest, passenger window down. 146.7db at 38hz
Hopefully new alt will improve score :ughdunno:
I thought this was a build log! from the 23 pages it looks like a CHATROOM! and you didnt do no DB at no HZ because as you no NO PICS MEANS IT DIDNT HAPPEN! :noob::jon::noob:
I was busy doing my run, didn't have time to record myself. But I do have a scoresheet rofl
well then scan that shEEt so I can get my respect for you at a descent level LMAO!
Whew man did it come out good. I miss my x-cons but i can tell your enjoying them. Build came out sick and im loving that box looks really nice. I think those are great numbers though i was putting just a tad bit better numbers. Gotta remember to 38hz and 149s is really good.. Now you make me want to meter my btls they are defiantly louder but boy do i miss the sq the x-cons had.
Thanks. And the amp is set fairly low right now :D
nice score :fing34: ... that is at 51hz it says?? Barely can read that....
I played a 38hz tone so I'm not sure where they got that number from. :ughdunno:
I call fakes!!! lol :peepwall:
Show was pretty fun, fair amount of cars. Got a demo of a escalade with 2 18" L7s and two warhorses. Also heard big wills ride :D
what car besides yours, did you really like?????
The escalade with kicker stuff was sick. Pretty sweet build...
But wills was louder. Both awesome trucks.
Also heard a hybrid audio demo car, all sq, sounded amazing.
:morepower1: :morepower1:
I think i need to make a road trip to AZ for a show weekend, hear all these awesome cars. :peepwall:
