Hmm, maybe its more of a baffle stretched to an end vs a actual pod. Once I wrap it in pleather I could probably screw it down from the back. Or that's the plan :P
  • Replies 366
  • Views 27.5k
  • Pulled off door panel, did another layer of resin and mat. Tomorrow lots of sanding and bondo!
  • CrazyKenKid
    CrazyKenKid
    hey no worries man! any time I can help out no problem! it is funny though how it was almost 3db differences from the TL vs the Makeitlouder meter. because when I was using it was always +/- 0.75db o
  • Not sure how to calibrate it And my dmm certainly isn't fancy, but I figured if it's reading a constant voltage then it's probably working Perhaps because we're at different altitudes and climates?
You look stunning with your dust mask on :) I hope you were smiling for that picture :)
Can't wait to see your door pods!
Haha thanks, after Tirefryr told me it doesn't do anything, I bought a respirator :P
Me too! Just bought some pleather and foam.
I should have made the fiberglass go all the way to the corner, instead of stopping short a few inches, original plan was to shave it down and try and make it flush... yeah wasn't happening :P
Still need to mount the baffle / pod to door panel. I don't think it came out GREAT, but good enough for now. Time to mount it and move on to next side.
I'll post more pictures in a couple days once I get my cross overs in and put the doors back on. :)
Looks good.
If it were me, I would fill that whole pocket. I think it would flow better on the door.
Ya I agree. Im contemplating filling the otherside and just redoing this one later.
I think I will...
Mess of a garage lol.
Okay so I thought about doing the fiberglass all the way to end of the pocket, then decided I'll try and make it smaller so I can still use the pocket area, and make the edge of baffle slant down... So we'll see how this turns out.
If it works I'll redo the other door to match, or start all over and fill the entire pocket... :trippy:
Good stuff that 1200 XS power ain't no joke Good shit seeing you jump off the cliff into fiberglassing :fing34:
my setup might look stupid but maybe it can inspire something.
I understand what you have planned most likely be cleaner but them D1200's will help out.
MDF cradle with MDF piece in back to hold disto and fuse block
:turkey:
Edited by crunkjuice1
:turkey:
Nice little extra electrical system setup in the back :)
I bought an extra one to help out on the voltage until I can get a new alt, seems I'll have to buy another pretty soon.
Now that I've started glassing I'm thinking what else I could try :P
I still need to get the hang of it tho, perhaps some A-pillar tweeter pods
hell yea practice makes perfect!
Thanks I just have to switch out that switch with a relay so the voltmeter on distro block turns on and off by itself.
:popcorn:
What kind of fabric did you use? Fleece?
Just a old cotton shirt, Although fleece may be easier to stretch / work with.
Dont use fleece, I was reading Ponte is a better fabric to work with. It is what swimsuits are made out of and they carry them at fabric stores (just a heads up).
I'll have to buy some next time and try it out. :drink40:
If my computer didnt crash the other day I would have given more info but that is all I can remember at the moment. Fleece will work but Ponte is much better and easier to work with if you can get your hands on some.
Polyester grill cloth works as well. Fleece sux imo, way to absorbant for my tastes.
I'm half way through doing the other door, starting to get sick of it, back aches from being hunched over for four hours :P
This. Ponte works great stretches really easy and does not soak up all your resin like fleece does. Get the 100% polyester.
So I almost finished the other door, but didn't do any test fit to make sure it wouldn't hit the dash when the door closed... Whatdoya know? It hits... Gah, I'm going to consider this a good learning experience.
In the following weeks I'll redo both doors, final, for real. :D
Any way here's some pics of the other side, until I found out it didn't clear, LOL.
How much does it hit by, try shaving down where the speaker mounts if its not by that much?
This is what I had to do to my passenger side pod, I just kept grinding it down and test fitting until it fit in.
