Posted March 11, 201115 yr Right now I have the following:Shitty H/U, replacing that real real soon, but that and my amp are tuned to prevent clipping.Audiopipe AP15001D, 1500W @ 1Ω / 950W @ 2Ω (LINK HERE TO OFFICIAL SITE WITH SPECS)2 - Fi BL 12 Dual 2ΩEnclosure 2.4 ft³ ported tuned to 32HzEnclosure 1.5 ft³ ported tuned to 42Hz (41Hz if sub sits ass-out)Horrible 80 amp alternator (It's a 2.4L 4 Cyl Mitsubishi Galant)So with all that, my questions arise:1. Would it be better to run the one sub at 1500W, or both subs at 475W each @ 2Ω.Keep in mind, that my alt is probably already starving my amp and it most likely isn't pushing out the full 1500w.I also thought about running them @ .5Ω, but to be quite honest, I don't think my amp can handle it.2. Are there any problems running two subs in two different boxes off the same amp?Initial reaction is yes, it is bad, but I can't think of a reason why.
March 11, 201115 yr Who said it's fine to run two subs in two different boxes? I'm running 2 isoberic driver kits out of 2 seperate (identical) enclosures off of one amp ... no problems ...I do not understand why you would have 2 different enclsoures (different sizes and different tuning frequiencies) ???
March 11, 201115 yr Author Welcome To SSA !!! Thanks Who said it's fine to run two subs in two different boxes? You need slapping.I never actually read anything about whether it is ok or not. It is just an option with what I have atm.Who said it's fine to run two subs in two different boxes? I'm running 2 isoberic driver kits out of 2 seperate (identical) enclosures off of one amp ... no problems ...I do not understand why you would have 2 different enclsoures (different sizes and different tuning frequiencies) ???First sub I got was an Eclipse 8122.4 SVC 4Ω, I knew it would be temporary so I grabbed an (overpriced) enclosure from AudioExpress. The enclosure itself has just been sitting in my garage for the last couple months since I built the current 2.4 ft³ enclosure for the Fi BL 12.I'm just trying to find an option to possibly run my stuff more efficiently till I get a new alt and another amp.
March 11, 201115 yr It won't hurt anything at all to have them in seperate boxes.... I (or anyone else for that matter) just won't be able to tell you how they will perform like that. It may work great, or they might have cancellation issues.... Who really knows... Edited March 11, 201115 yr by 95Honda
March 11, 201115 yr very odd... I think you should use the two different boxes and let us know how they sound....
March 11, 201115 yr Who said it's fine to run two subs in two different boxes? I'm running 2 isoberic driver kits out of 2 seperate (identical) enclosures off of one amp ... no problems ...I do not understand why you would have 2 different enclsoures (different sizes and different tuning frequiencies) ???one for the lows and one for the highs
March 11, 201115 yr Author Yea I was thinkin it would be better for SQ since it has a better overall range, but they also wouldn't be able to play anything at full power. So I think it's more of an SQ thing, but we'll see what happens. I'll probably hook it up sometime today or tomorrow.
March 13, 201115 yr Author Odd thing happened. The one that was already in the car was wired down to 1Ω.I connected the second one in series putting it at 4Ω.I connected both together in parallel which brought them down to 1Ω ?????Not a bad thing, but very odd. Haven't had a chance to test it just yet, but I will later today. It's my birthday so I'm a little busy.
March 14, 201115 yr Odd thing happened. The one that was already in the car was wired down to 1Ω.I connected the second one in series putting it at 4Ω.I connected both together in parallel which brought them down to 1Ω ?????Not a bad thing, but very odd. Haven't had a chance to test it just yet, but I will later today. It's my birthday so I'm a little busy. False. One in series and one in parallel will be wired down to 2 ohms final.
March 14, 201115 yr Odd thing happened. The one that was already in the car was wired down to 1Ω.I connected the second one in series putting it at 4Ω.I connected both together in parallel which brought them down to 1Ω ?????Not a bad thing, but very odd. Haven't had a chance to test it just yet, but I will later today. It's my birthday so I'm a little busy. False. One in series and one in parallel will be wired down to 2 ohms final.False. 1/((1/4)+(1/1)) = .8ohms.
March 14, 201115 yr Who said it's fine to run two subs in two different boxes? I'm running 2 isoberic driver kits out of 2 seperate (identical) enclosures off of one amp ... no problems ...I do not understand why you would have 2 different enclsoures (different sizes and different tuning frequiencies) ???And no one else understands why you have drivers that are designed wrong such in a way that running them isobaric is an advantage. And yes, I know what it does just wouldn't pick a driver that forced me to. Great opportunity for the manufacturer to sell you two since they didn't design the one right.very odd... I think you should use the two different boxes and let us know how they sound.... No don't tell us. If it works it is luck and not a plan and someone will copy it. As Honda said, may or may not work. Answer/response won't be scientific or helpful so its better to just like it if it works for you. In general it isn't the right way to go about getting the Frequency response you are looking for. I'd definitely encourage the OP to think about his goals and then design an enclosure that matches those goals. I can surely bet one thing, the two different boxes are not for an SQ reason.
March 15, 201115 yr Author Odd thing happened. The one that was already in the car was wired down to 1Ω.I connected the second one in series putting it at 4Ω.I connected both together in parallel which brought them down to 1Ω ?????Not a bad thing, but very odd. Haven't had a chance to test it just yet, but I will later today. It's my birthday so I'm a little busy. False. One in series and one in parallel will be wired down to 2 ohms final.False. 1/((1/4)+(1/1)) = .8ohms.I'm not sure how that math worked out tbh, but according to what I actually read off the subs, it is correct.As far as the quality, it made it better but I'm betting that's only because of the smaller enclosure being actually inside the cabin. It is also louder.Although this isn't really an end-game thing. Just something for a couple weeks as I get some time to build a proper enclosure.To be truthful though, I am feeling a little uneasy about running one sub in series while the other is in parallel. Can't explain why. I just am.
March 15, 201115 yr Run one bl on that amp, and build a good box for the 2 (same, I hope so) bl's.You'll upgrade your amp later, or you can simply get a second amp like this AP 1500. It's the cheapest solution !
March 15, 201115 yr Im with notorious.. Run just one BL now, see how the amp and alt handles it and see if you like it... If its not enough then build you another box ONE box tuned right for the 2 subs and upgrade your amp and you will have a nice set up. Running 2 subs in 2 differnet tuned boxes might or might not work..... it all comes down to personal prefernce and what you will like. ...hope this was helpful
March 15, 201115 yr Author I had been running just the one BL in the 2.4ft³ enclosure for a couple months. I am liking the current setup with the two boxes better, but am uncomfortable running one sub in series while the other is in parallel.Money is a bit tight and I don't want to just get another amp without upgrading my alternator first. H/O Alt + amp will run me about $500.Building a new enclosure though is more within my current limits. The problem with my last one (image below) was that I do not have many wood working tools and had to resort to having Home Depot cut the wood for me and the guy didn't even know what 1/16th inch was so it came out really messed up and needed filling (used "Great Stuff" but should have used some fiberglass filler like Kitty Hair). Now I learned that I can buy a $40 circular saw and make a guide for it and can run that for both the straight cuts and even angles.TLDR:Will buy and build enclosure first, 1/0 Welding Cable second, H/O Alternator third, second amp forth. Will wire both subs to 1Ω each to their own amp.Next enclosure will likely be 5ft³ tuned to 35Hz or 36Hz.
March 17, 201115 yr ya im in the same boat as u if i wanted to get another SSD i dont wanna wire them parallel and 1 in a series and dont have the money or another amp... 2.4cubic feet i hope that is a sealed enclosure, ya if you buy a circular saw it would be awesome but its gonna be hard to get it straight when i build a box, i cut an extra inch with the circular saw then i run the peice i cut through a table saw and cut that extra inch off to get it perfectly straight
March 17, 201115 yr Author ya im in the same boat as u if i wanted to get another SSD i dont wanna wire them parallel and 1 in a series and dont have the money or another amp... 2.4cubic feet i hope that is a sealed enclosure, ya if you buy a circular saw it would be awesome but its gonna be hard to get it straight when i build a box, i cut an extra inch with the circular saw then i run the peice i cut through a table saw and cut that extra inch off to get it perfectly straightI don't have a table saw or access to one. Being able to build a guide for a circular saw gives you a lot of options though for perfectly straight cuts.My problem is I just spent more money than I wanted to on a funeral a few months ago, money I had been saving for a long long time, and I am trying to work for it back.
