Posted March 16, 201114 yr Vehicle Make and Model: 1998 Ford ExplorerDirect of Box/Subs: Subs up, port towards drivers side.Sealed or Ported: PortedNumber of Subs: 2Brand and Model of Subs: Sundown Audio SA-12Max Dimensions: 38 in. width, 18in. height, depth shouldn't be an issue (plus I forgot the measurement haha)Zip Code for Shipping Quote: 76708Hey, I have a few special requests...I listen to a lot of slowed music (decaf etc.) and love bass around 27-35 hertz so I would like for the box to be tuned a little lower than what Jacob recommends. Probably 26, but whatever gives me the most balanced response and can still dominate between 27-35. I've experimented and found that when the ports are aimed on the drivers side of my car (left if I had the hatch open and was looking out the windshield. Just in case I say the wrong side, but definitely left.) I get a lot more on the low end so that's why I ask for the port to be that way. and with subs up port side I can experiment with different configurations.One more thing, I want to mount my amp to the back of the box, so how much extra would it cost to get the back double baffled? If this isn't possible or just a bad idea just let me know. Oh and throw on flush mount to the quote too.Thanks in advance for reading my huge ocd request.
March 17, 201114 yr I would suggest the lowest tuning to be 28 Hz as anything lower is not really practical for car audio. Is 28 ok for you?Andrew
March 17, 201114 yr Author I would suggest the lowest tuning to be 28 Hz as anything lower is not really practical for car audio. Is 28 ok for you?AndrewAs long as the response is smooth. The only reason I want to be tuned so low is so that I can play any and everything (to a certain extent of course) safely. If you can do that with a 28hz tuning then that's perfect.
March 22, 201114 yr Here is what I came up with:20 deep18 tall33.5 wide3.5 cubes28 HzFlush mount. If you would like me to drop it down to 27 Hz tuning the box will just become wider. Andrew
March 23, 201114 yr Author Heck yeah I want it dropped to 27!Sounds like a solid plan...what's it gonna run me?EDIT: Slot or Aeroported? Edited March 23, 201114 yr by An-i-no
March 23, 201114 yr Ok here we go:20 deep18 tall34.25 wide3.5 @ 27 HzSlot PortFlush MountSubs up, port back on driver side$152 plus shipping This price includes carpet of your choice. I have black and salt and peper right now. I can also get gray. Andrew
March 24, 201114 yr Author Ok here we go:20 deep18 tall34.25 wide3.5 @ 27 HzSlot PortFlush MountSubs up, port back on driver side$152 plus shipping This price includes carpet of your choice. I have black and salt and peper right now. I can also get gray. AndrewSubs up port back? I need subs up port driver's side so I can push the box all the way up againt my backseat...hope that doesnt take a major redesign, sorry...Oh and salt & pepper carpet please? Edited March 24, 201114 yr by An-i-no
March 24, 201114 yr Author Ok so subs up and port up?Sorry for the confusion. AndrewNo problem! I know i get nit picky and confusing at times lol.I need subs UP port SIDE. I just want it to fire straight out of the side.
March 24, 201114 yr Ok so subs up, port out the side of the box facing your wheel/driver side of the car? I have never received a request for a box design like this so I just want to make sureAndrew
March 24, 201114 yr Author Ok so subs up, port out the side of the box facing your wheel/driver side of the car? I have never received a request for a box design like this so I just want to make sureAndrewYes, exactly. Subs up, port to the side. If you have to make it deeper then that's fine. Don't worry too much about it being "at" the drivers side. I just need subs up, ports to the side. This way, I can simply rotate it if I need to. For example, with subs up, port side I would start with subs up port left. I can rotate it 90 degrees and have subs up port back, rotate it another 90 degrees and have subs up port right. That's all I really want is versatility. PS. Did you read my request about the double baffle on the back of the box to mount amps to? That would be really awesome...thanks in advance, and sorry for all the trouble...
March 25, 201114 yr Ok I will get a sketch just to verify the port/sub position. I could put an extra piece on the back but I'm not sure mounting your amps on the box would be the best idea. Some times excessive vibration could rattle some of the components loose. Andrew
March 25, 201114 yr Author You're awesome man. I honestly appreciate you taking the time to make sure everything is right and responding to all my requests (even if they get wacky at times). I really do apologize for all the confusion.I only have three real places to mount the amps. On the back of my seat (which the box will be pushed up against anyway) on the box, or on the floor in the cargo area but that would make it where I can't put anything on top of the amps. I'd really rather mount them on the box with the double baffle though...
April 21, 201114 yr Something like this. I know I put three subs in there, I had two but they looked lonely... lol This is not to scale in anyway....Andrew
