Posted March 21, 201115 yr I was wondering if anyone has managed to put one or 2 15" FI audio subs in an extended cab ranger. I have a 95 that I would like to upgrade. I currently have 2 Jensen competition series 12's in a deathbox II and its just not enough for me. I have seen 15" subs in rangers before, but I would worry about fitting a big enough box so they sound nice, and FI subs seem to need slightly larger boxes than some other 15sBTW, If anyone is selling USED amps or subs that are in good shape, I would love to know!
March 23, 201115 yr bust out a tape measure and see what you got to work with, long as you have the room
March 23, 201115 yr What type of power are you running/want to run? Are you looking to have a sealed or ported box?
March 23, 201115 yr i have a '95 ext. cab ranger myself. i have had plenty of set-ups with 2 15's. i had 2 15" kicker l7's in a ported box, iv had 2 15" crunch ground pounders, also 3 12's in a sealed box befor. i just removed my 2 12" mtx 9500's the other day. if u take the jump seats out, u can get a total of around 52" for length, 17 depth, and id say around 30 for heith and those are the MAX spec's i myself have found.i am 6'2" and those are the maxes for the depth. hope it helps bro!!!Ford for the winnnnnhaP.S...if u plan on getting a big amp, i suggjest doing "the big 3" and adding a second bat. i have a kicker zx1500.1 (150 amp) and it would almost shut off my truck when turned up. i solved most of the problem by doing the big three and getting a wal-mart (yes i said wal-mart) big boat battery. there around $85 and cant go wrong. YOU DONT NEED TO SEPND $175 ON A OPTIMA!! DONT lol everyone says the optima is the only way to go. well its not. and i have proof. Edited March 23, 201115 yr by Lantz
March 23, 201115 yr BTW, If anyone is selling USED amps or subs that are in good shape, I would love to know!Check the For Sale section: http://www.soundsolutionsaudio.com/forum/forum/16-for-salewanted/
March 24, 201115 yr Author i have a '95 ext. cab ranger myself. i have had plenty of set-ups with 2 15's. i had 2 15" kicker l7's in a ported box, iv had 2 15" crunch ground pounders, also 3 12's in a sealed box befor. i just removed my 2 12" mtx 9500's the other day. if u take the jump seats out, u can get a total of around 52" for length, 17 depth, and id say around 30 for heith and those are the MAX spec's i myself have found.i am 6'2" and those are the maxes for the depth. hope it helps bro!!!Ford for the winnnnnhaP.S...if u plan on getting a big amp, i suggjest doing "the big 3" and adding a second bat. i have a kicker zx1500.1 (150 amp) and it would almost shut off my truck when turned up. i solved most of the problem by doing the big three and getting a wal-mart (yes i said wal-mart) big boat battery. there around $85 and cant go wrong. YOU DONT NEED TO SEPND $175 ON A OPTIMA!! DONT lol everyone says the optima is the only way to go. well its not. and i have proof.Thank you very much for the info. I didnt want to spend forever trying to design a box that would be big enough if it was impossible. Did you have the subs firing up? or forward?
March 24, 201115 yr i have a '95 ext. cab ranger myself. i have had plenty of set-ups with 2 15's. i had 2 15" kicker l7's in a ported box, iv had 2 15" crunch ground pounders, also 3 12's in a sealed box befor. i just removed my 2 12" mtx 9500's the other day. if u take the jump seats out, u can get a total of around 52" for length, 17 depth, and id say around 30 for heith and those are the MAX spec's i myself have found.i am 6'2" and those are the maxes for the depth. hope it helps bro!!!Ford for the winnnnnhaP.S...if u plan on getting a big amp, i suggjest doing "the big 3" and adding a second bat. i have a kicker zx1500.1 (150 amp) and it would almost shut off my truck when turned up. i solved most of the problem by doing the big three and getting a wal-mart (yes i said wal-mart) big boat battery. there around $85 and cant go wrong. YOU DONT NEED TO SEPND $175 ON A OPTIMA!! DONT lol everyone says the optima is the only way to go. well its not. and i have proof.Yeah Optimas aren't great for car audio. May I ask if this "big boat walmart battery" is a sealed agm?
March 24, 201115 yr Author i have a '95 ext. cab ranger myself. i have had plenty of set-ups with 2 15's. i had 2 15" kicker l7's in a ported box, iv had 2 15" crunch ground pounders, also 3 12's in a sealed box befor. i just removed my 2 12" mtx 9500's the other day. if u take the jump seats out, u can get a total of around 52" for length, 17 depth, and id say around 30 for heith and those are the MAX spec's i myself have found.i am 6'2" and those are the maxes for the depth. hope it helps bro!!!Ford for the winnnnnhaP.S...if u plan on getting a big amp, i suggjest doing "the big 3" and adding a second bat. i have a kicker zx1500.1 (150 amp) and it would almost shut off my truck when turned up. i solved most of the problem by doing the big three and getting a wal-mart (yes i said wal-mart) big boat battery. there around $85 and cant go wrong. YOU DONT NEED TO SEPND $175 ON A OPTIMA!! DONT lol everyone says the optima is the only way to go. well its not. and i have proof.Yeah Optimas aren't great for car audio. May I ask if this "big boat walmart battery" is a sealed agm?I think I know what battery he is talking about, and if so, its just a normal lead acid. On a ranger theres room under the hoot for 2 more batteries, so all is good there. My problem is, my ranger has a 95amp alternater, so i will need to upgrade that. I already get my voltage gauge dropping with just 2 jensen 12's and a 250w amp, or just my headlights and fog lights (The fogs are 150w HID variety. They were free and BRIGHT)
March 24, 201115 yr i have a '95 ext. cab ranger myself. i have had plenty of set-ups with 2 15's. i had 2 15" kicker l7's in a ported box, iv had 2 15" crunch ground pounders, also 3 12's in a sealed box befor. i just removed my 2 12" mtx 9500's the other day. if u take the jump seats out, u can get a total of around 52" for length, 17 depth, and id say around 30 for heith and those are the MAX spec's i myself have found.i am 6'2" and those are the maxes for the depth. hope it helps bro!!!Ford for the winnnnnhaP.S...if u plan on getting a big amp, i suggjest doing "the big 3" and adding a second bat. i have a kicker zx1500.1 (150 amp) and it would almost shut off my truck when turned up. i solved most of the problem by doing the big three and getting a wal-mart (yes i said wal-mart) big boat battery. there around $85 and cant go wrong. YOU DONT NEED TO SEPND $175 ON A OPTIMA!! DONT lol everyone says the optima is the only way to go. well its not. and i have proof.Yeah Optimas aren't great for car audio. May I ask if this "big boat walmart battery" is a sealed agm?I think I know what battery he is talking about, and if so, its just a normal lead acid. On a ranger theres room under the hoot for 2 more batteries, so all is good there. My problem is, my ranger has a 95amp alternater, so i will need to upgrade that. I already get my voltage gauge dropping with just 2 jensen 12's and a 250w amp, or just my headlights and fog lights (The fogs are 150w HID variety. They were free and BRIGHT)That's pretty sweet you have extra space under the hood for batts I'm jealous.Yeah just don't put a normal acid batt inside the cabin, sealed agm is fine.
March 24, 201115 yr Author i have a '95 ext. cab ranger myself. i have had plenty of set-ups with 2 15's. i had 2 15" kicker l7's in a ported box, iv had 2 15" crunch ground pounders, also 3 12's in a sealed box befor. i just removed my 2 12" mtx 9500's the other day. if u take the jump seats out, u can get a total of around 52" for length, 17 depth, and id say around 30 for heith and those are the MAX spec's i myself have found.i am 6'2" and those are the maxes for the depth. hope it helps bro!!!Ford for the winnnnnhaP.S...if u plan on getting a big amp, i suggjest doing "the big 3" and adding a second bat. i have a kicker zx1500.1 (150 amp) and it would almost shut off my truck when turned up. i solved most of the problem by doing the big three and getting a wal-mart (yes i said wal-mart) big boat battery. there around $85 and cant go wrong. YOU DONT NEED TO SEPND $175 ON A OPTIMA!! DONT lol everyone says the optima is the only way to go. well its not. and i have proof.Yeah Optimas aren't great for car audio. May I ask if this "big boat walmart battery" is a sealed agm?I think I know what battery he is talking about, and if so, its just a normal lead acid. On a ranger theres room under the hoot for 2 more batteries, so all is good there. My problem is, my ranger has a 95amp alternater, so i will need to upgrade that. I already get my voltage gauge dropping with just 2 jensen 12's and a 250w amp, or just my headlights and fog lights (The fogs are 150w HID variety. They were free and BRIGHT)That's pretty sweet you have extra space under the hood for batts I'm jealous.Yeah just don't put a normal acid batt inside the cabin, sealed agm is fine.Heres the engine compartment. If you look on the lower left corner, theres room right there for one, and I cant remember where I could put a third. lolAnd since this is a car audio forum, two more pics. One is my BIG audio for my truckYes, I can scare people shitlessAnd the other is a BIG piston
March 24, 201115 yr Her is some pics that may be helpful to youhttp://www.ranger-forums.com/showthread.php?t=102894And you may want to talk to this guy and check out his build log.
March 24, 201115 yr Author What type of power are you running/want to run? Are you looking to have a sealed or ported box?I like the SQ of sealed, but I need to compete with type R's and W6's, so I'm guessing i will need to go ported. I wanna make sure people know who has the baddest system, and who makes the baddest subs
March 24, 201115 yr Author Her is some pics that may be helpful to youhttp://www.ranger-forums.com/showthread.php?t=102894And you may want to talk to this guy and check out his build log.Thanks for the info. I would love to go for this even if it is a LITTLE BIT overkill. xD
