  • 1 month later...
  • Replies 157
  • Views 19.1k
  • edouble101
    edouble101
    I heard it from the company itself and this is in their section.
  • DC Power Rob
    DC Power Rob
    Eric, I know exactly how to fix this, but your going to have to give me some time to fab it up. Basically we're just going to hang a backside idler pulley on the bottom alternator pivot bolt between t
  • Yes.
On my way to work today my alternator spiked over 17v and now is only charging at 13.0v. This is the second mysterious failure I have had with this alternator. Ironically when this happened I didn't even have my stereo above talking level.
What should I do?
April 25th 2011 was when the alternator failed the first time after being installed for a month. Now 4 months later it failed again.
Does this alternator have a bad voltage regulator?????
Thanks Kyle. I called Rob yesterday and left him a voicemail.
Eric, I saw that you dropped it off. We will take a look at the alternator and see what's up. We do have an idea of what's causing this problem but I want to make sure we're correct before I post about it. I will keep you updated though! Thanks for being a great hamster for the Hyundai's
Thank you for fixing the alternator. Maybe I will have consistently 14.4-14.7 voltage now as well.
Like I said on the phone if you have a customer with any questions about this install please contact me and I will help any way I can.
