This build will not be a rushed one.. I want to take my time, cause I rushed my last build. I have learned alot of stuff from other forums, but from the little time I have been looking at the amazing builds here..
I know I will be busy soon getting this beast running before any audio goes in, but I have also been working on some ideas.. It's not for sure cause if I can get to it I have been in contact with Mike Singer to design me a 4thorder for 12 12's.. I probably will be using some Alpine type R's (older models swr-1242d) for awhile until funds allow me to go further.. Mike said that using the alpines would not be a bad thing cause they do so well in sealed enclosures..
From what I have seen here, you guys are the 4thorder experts..I would like any advice or ideas anyone has..
Any ideas as far as audio is welcome. I have not ruled out using, DC, SUNDOWN, or even SKAR AUDIO...
Not sure what amps I will be using either.. any idea?
Thanx Guys
Jay
This is the Big Beast That will be the victim of my torture..
This Is the outer frame I came up with to get the idea of the room i have to work with.. This will be behind the second seat.. I want it to still have the 5 seats.
  • Replies 65
  • Views 8.9k
  • Address of page inserted into the media selection. It's Alive!!!
  • jaynanspl
    jaynanspl
    Hey guys just alittle small update.. got the final layer up for the headliner.. that means the enclosure will start soon Jay Resized to 86% (was 1024 x 768) - Click image to enlarge Resized to 86% (w
  • jaynanspl
    jaynanspl
    Well guys while I'm waiting for more funds to continue, I have been remeasuring everything that I think will work better for me and what I need.. I need your guys thoughts and opinions.. Resized t
You did not give your actual goal for this setup or the power that you are planning on using. If working on a budget for this setup maybe you could consider 12 12" DCONs. These subs seem to always get over looked because of their lower rms rating, but used as a fleet I think they would be great!! Just a thought...
I have not thought about the dcons.. thats now on my list of choices..
I was alittle tired today but made alittle vid.. and forgot how to embed a vid again..noob.giflol.gif
http://youtu.be/F10in2VhPq0
There you go! Use the insert media tab.
  • 3 weeks later...
Its been awhile since I have updated over here.. I know I put the vidz i wrong again, but everytime I use the media tab it never works right..
Jay
Jay
It's Alive!!!
Hey guys just alittle small update.. got the final layer up for the headliner.. that means the enclosure will start soon :peepwall:
Jay
What was the decision on the subs??? Tuned in for the build!
Resized to 86% (was 1022 x 500) - Click image to enlargeJays4thorderBuild2frt.jpg
Resized to 86% (was 1022 x 500) - Click image to enlargeJays4thorderBuild2bk.jpg
Resized to 86% (was 1022 x 500) - Click image to enlargeJays4thorderBuild2-1.jpg
Design looks cool to me. The first pic says "port will fire over rear seat"- How's that gonna fit behind the rear seat??? The older Burbs must have more space than I remember. :trippy:
I'm still hoping those 12 holes are for DCONS!!!!!
I will be watching this build! Good luck and have fun :)
As far as subs I would use the SA series from Sundown for your application. SA had been proven in hundreds of installs to handle really any amount of power, get crazy loud and sound good.
I honestly have not heard anything about DCON other than a few installs on this forum. It doesnt't mean that it isn't a good driver...
As far as amps, I like Crescendo. Good power, good price.
I did alittle dry fit just to see how shes going to look.. .. This is just the outer shell..she has more layers to come..yahoo.gif
View from the back
front view.. I know the gap is ugly but that will have more bracing and foamed up..
With the back seats up so I can check clearance..
I also vote for Dcons
Well I had to get back at it.. I know life will get better, but losing any body either ( person or animal ) sucks.. This will help my mind..
Strength Test.
Strength Test.
Video page address inserted into media tab:
Looks good n stout :drink40: good job, let's see some more progress.
A few pics.. not much alittle of the same.. I have only 3 more added pieces then I can start the sub baffle placement..
  • 4 weeks later...
Well I did get some stuff done today.. Not as much as I wanted but still progress.. everything is just dry fit..
Hey guys, had a talk with mike about my build and he said that Im on the right track with everything so far..:woot: I told him this was the specs so far..well with having 6 subs per side, i made the sealed side on each side alittle less than 6cu total.. and the ported will be 2cu per sub.. he said to stick with that. Should hammer and play nice and wide.. so i got the green light to proceed from the expert..:lol:
Looks good! Can't wait to see it playing...I'm doing a similar build this fall
Looking Good!!! Do Work!!!
