I have a small problem, I have two plates that will be joined with Lamello biscuits at a 45 degree angle.
I have found some solution that uses tape at one side, but I feel that it will not put enough pressure on the plates.
Does someone know a good way to clamp them together?
edit:;
I forgot to mention that the end of the plates that will be used to join them together are cut at a 22,5 degree angle.
Edited by Dammed
They make 45 degree angle woodworking clamps. If you were welding them they make magnets with 45's.
I have seen the clamps at hardware stores. Handy tool to have.
welding would not work since it's wooden plates.
I have looked around at hardware stores, but I couldn't find a 45 degree wood clamp.
As a student that goes over my budget, especially since I live in Norway so the shipping would be to much.
I'm just going to clamp together two joints. So I was more looking for a solution my making a small jig of some kind.
But thanks for the link.
