Posted May 5, 201115 yr So, unfortunately i don't think i will be able to get the hight i need for 15s in a regular blow through. i have been looking in doing some sort of bandpass blow through with the chamber firing into the truck from the bed. i have read other posts and things but there seem to be too many different opinions and not facts. Any information for me would be greatly appreciated. I have seemed to be more focused of a 6th order. i like the way its ported inside a port but i do NOT have much knowledge on this so i'm looking forward to learning more about it. Would a bandpass be my best option, if so which one and why?i was looking to do something like this.
May 5, 201115 yr Budget = BROKE!Vehicle = Busted! :roflmao: :roflmao: :roflmao: :roflmao: :roflmao: just kiddin got nothin but love for DBL! He has a s10 97ish I believe! Drivers I think he is going with mayhems not 100% though! for power has the two SAZ3k!Good luck with this DBL if you need any help dont hesitate.............to call someone else! LOL!
May 5, 201115 yr S10s are good at getting loud and mayhems are killer drivers Well now that we've established vehicle and what not, time for someone that actually knows something about 4th orders etc to chime in
May 6, 201115 yr Not enough info in your post to answer anything. Goals, music prefs, etc...Curious on your room comment as well, is there a reason you can "tip" the manifold in the BP but that you won't in a normal ported?
May 6, 201115 yr Author I figured you guys knew what i was running. i am running 2 aa mayhem 15's with two sundown 3ks in a 98 s10. a 250 amp alt a kinetik 1800 unfront and a 2400 in the back. My goals are for just a daily ground pounder. i would like tuning to be around 30-32 hz but i do not know how to tune a bp. im not sure what you mean by tip the manifold, to do a traditional blow through i would do my subs flush with my back panel but i cannot get enough height to put the drivers through the cut .
May 6, 201115 yr Sorry, should have used the word baffle and not manifold. Any reason you can't tip it?
May 6, 201115 yr Author the most i can get out for height is 16.5 subs od is 15.6 and i need room for the box and for the boot.
May 6, 201115 yr And if you tip the subs at a 45 degree angle (or even much less) they will fit easily
May 6, 201115 yr the most i can get out for height is 16.5 subs od is 15.6 and i need room for the box and for the boot.But if you angle / slant the mounting baffle then they could fit M5 beat me
May 6, 201115 yr Author And if you tip the subs at a 45 degree angle (or even much less) they will fit easily well would you be able to help me with a box design?
May 8, 201114 yr But with the angled baffle, you have to worry about your basket/motor hitting the bottom of the box.
May 8, 201114 yr But with the angled baffle, you have to worry about your basket/motor hitting the bottom of the box.Good point, would have to make sure you'd have the clearance before building box. Computers and calculators ftw
May 13, 201114 yr Author solid point. so what could my other options be? I have been pondering on how to do it but i feel like i have ran out of options.
