Posted May 6, 201114 yr Well decided to take my stuff out of my 09 Ford Escape and see how it sounds in my s10 for a couple of weeks. I Know the battery needs moved and its unsafe on top of the box but this was just a throw in setup to see how it sounds. It will be secured down tomorrow. The truck is only used to pull my kubota bx25 from job to job so it doesn't get used every day but have to have some kinda tunes.The only thing that i don't like is the subs are quad 1ohm coils but they read 1.2ohms and the final ohm load is 2.9-2.6ohms depending on the mm i used. So with out another battery and a bigger alternator they arn't getting all the amp has to offer but it does get LOUDSystem includesPioneer DEH-7200HD deckTc Sounds Axis subsCrossfire VR4000D ampBig 3Knukoncepts 1/0 wireKinetik KHC 2400 battery Box comes in around 6.4cf net tuned to 32hzI have a video we took today of it. The whole box moves and the battery bounces around. Will up load it later. Edited May 6, 201114 yr by jj1479
May 6, 201114 yr Author What do you think of the Axis subs?At first when I had them in my escape I had them in the box that was built for the Fi Bls that I had an they honestly didn't sound good at all. But now that they are in a bigger box with alot more port they sound 100% better.BUT now I have a problem, their was a brace between the subs in the box that attached the front to the port and it just broke loose a couple of minutes ago so now i have to rip the seats back out and take the subs out to fix.
May 6, 201114 yr Author Love how the tc baskets look.Box looks great too, lots of port Ya I like the way they look but I liked the look of my tc 3000's better. They had the black baskets and the vents for the coils had wire mesh in them. The box was actually done for over a month now just didn't have time to put it in. I kinda feel down my hardwood steps on April 12th due too my wife using pledge on them and i twisted my hip and pulled the tendons real bad so i couldn't walk for awhile. But i couldn't wait any longer it had to go in.
May 6, 201114 yr Tough break on the enclosure. Love the look of the amp with dual 1/0 inputs. Hope you don't have to stop fast cause you may be wearing that bat as a hat!
