Posted May 29, 201115 yr I ordered (2) SA-10 D4's And a Crescendo BC2000D And A few Shuriken BT-80's, and Some Kicker 0Gauge wire. I NEED A T-line Design For (2) SA-10's please.Or A 4th Order, ORRR A 26Hz Tuning With LOTS of port area Near full potential.
May 31, 201115 yr I ordered (2) SA-10 D4's And a Crescendo BC2000D And A few Shuriken BT-80's, and Some Kicker 0Gauge wire. I NEED A T-line Design For (2) SA-10's please.Or A 4th Order, ORRR A 26Hz Tuning With LOTS of port area Near full potential.What do those alignments have in common?
May 31, 201115 yr I ordered (2) SA-10 D4's And a Crescendo BC2000D And A few Shuriken BT-80's, and Some Kicker 0Gauge wire. I NEED A T-line Design For (2) SA-10's please.Or A 4th Order, ORRR A 26Hz Tuning With LOTS of port area Near full potential.Your woofers will blow with 2000 watts at 26hz with lots of port. Unless you plan to have the gain on the amp mostly to the left you need bigger speakers for what you're trying to do. Yeah it's 90% install and 10% equipment, but...sa-10's don't do that. Sorry.
May 31, 201115 yr I ordered (2) SA-10 D4's And a Crescendo BC2000D And A few Shuriken BT-80's, and Some Kicker 0Gauge wire. I NEED A T-line Design For (2) SA-10's please.Or A 4th Order, ORRR A 26Hz Tuning With LOTS of port area Near full potential.Your woofers will blow with 2000 watts at 26hz with lots of port. Unless you plan to have the gain on the amp mostly to the left you need bigger speakers for what you're trying to do. Yeah it's 90% install and 10% equipment, but...sa-10's don't do that. Sorry.Port area(in most cases) won't cause mechanical failure, internal volume is the most important factor there.
June 1, 201115 yr Author Well Does THUMPER Have a Dual 10 Low tuned( 27-31HZ) Enclosure for $100.00 Total price.
July 2, 201114 yr Low tuning is the way to go but u need a lot of power tk back it up. Then its like being kicked in the head when the bass cuts in. I get it
