Does the SAZ-2500D come with a remote bass knob? I cant find any pics...
It does...
It does...
Cool just wanted to make sure, I'm gonna go with the sundown instead of the Rockford T2500-bdcp(sinc the Rockford's subsonic filter isnt adjustable). Just wanted to make sure cause I didnt want to have to control the sub using my Head unit lol
what HU do you have???
Just to eliminate any doubt in my answer... Excerpt from SSA Store...
SPECIFICATIONS:
Digital Class-D Linkable Mono Block Amplifier
Double Sided Through Hole Epoxy PCB
1 Ohm Stability
Daisy-Chain Through Output RCA
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
RCA Line Input and Master Output
24dB Octave Crossover Slope
24dB Octave Variable Subsonic Crossover Slope
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Wired Remote Controller
I cant really afford anything better but Kenwood X595. I love how they have 4volt pre outs. most company's dont have this.
SPECIFICATIONS:
1 Ohm Stability
Variable Bass Boost
Thank you yea I saw these specs and saw it said wired remote but just wanted to make sure that it was a knob remote.
Don't feel bad, I run an Alpine that is almost 10 years old. Still works great too, just no fancy stuff.
SPECIFICATIONS:
1 Ohm Stability
Variable Bass Boost
Yes and the good thing about these is that it's a gain control, not a bass boost knob. I also believe that when you set your gains if you turn the knob all the way up you only reach what your gains are set at. It doesn't act like your turning your gain setting on the amp all the way up.
