Posted June 2, 201114 yr If I have two 1-Ohm 12" FI SSD's with the VC wired in series, and the speakers wired parallel making it 1-ohm. If they are hooked into a Sundown SAZ-1000d does that give the both of them 1000 watts (approx) a piece or do they both share the wealth and get 500 watts (approx) each?? In the same aspects of things, if there individually wired with the VC's wired series = 2 ohms, if the amp puts out 600 watts @ 2-ohms, does that mean there getting (approx) 300 watts a piece?? I'm being held by pirates and this is the only thing that will set me free.
June 2, 201114 yr If you wire the amp to 1 ohm they will get 500 watts a piece. Wire them in series (2 ohms a piece) and hook each of them up to a channel on the amp. The sundowns are internally paralleled so when you hook it up this way the amp will see a 1 ohm final load.
June 2, 201114 yr Author If you wire the amp to 1 ohm they will get 500 watts a piece. Wire them in series (2 ohms a piece) and hook each of them up to a channel on the amp. The sundowns are internally paralleled so when you hook it up this way the amp will see a 1 ohm final load.So wiring them together @ 1-ohm or wiring them seperate @ 2-ohms isn't gonna make much of a difference??
June 2, 201114 yr These are your wiring options:The lower the impedance the more power the amp will make (it was also require more amperage).Whatever the power it is, it will be divided amongst the drivers.Ex: at 1ohm an amp produces 500watts, and your using two drivers, each will see around 250 watts. In simplest terms
June 2, 201114 yr If you wire the amp to 1 ohm they will get 500 watts a piece. Wire them in series (2 ohms a piece) and hook each of them up to a channel on the amp. The sundowns are internally paralleled so when you hook it up this way the amp will see a 1 ohm final load.So wiring them together @ 1-ohm or wiring them seperate @ 2-ohms isn't gonna make much of a difference??You have 2 DVC 1ohm subs correct? Wire each sub in series to bring them up to 2 ohms. There appears to be 2 channels on the amp but it's really only one. It's internally paralleled. So when you wire each sub up to 2 ohms and then hook one sub to each channel your paralleling them to bring your final load down to one ohm.
