June 6, 201115 yr Rebuild for my brother part 2Looks great! But how big is it? In the video it looks small. Edited June 6, 201115 yr by ricksi30
June 6, 201115 yr Author Rebuild for my brother part 2Looks great! But how big is it? In the video it looks small.2 cubes netBOOOO what did u do hook it up as a mid I WANT BASSSSS!Hahah, we had her turned all the way down to build suspenseWhat made you use fiberglass over silicone and titebond over liquidnails?Because fiberglass actually adds strength to the box, and when you paint the resin over the inside of the box it clogs up the pores in the mdf.And titebond creates a really strong bond, I'm not a fan of liquidnails.
June 9, 201115 yr What made you use fiberglass over silicone and titebond over liquidnails?Fiberglass adds strenght and seals it up. But the titebond(=woodglue) should already seal it up and the bond is stronger then the MDF itself. Liquidnails doesn't has that strong of a bond.EDIt: you kind of didn't take the time to do it right. Have you sanded down the resin? Edited June 9, 201115 yr by kirill007
June 10, 201115 yr Author What made you use fiberglass over silicone and titebond over liquidnails?Fiberglass adds strenght and seals it up. But the titebond(=woodglue) should already seal it up and the bond is stronger then the MDF itself. Liquidnails doesn't has that strong of a bond.EDIt: you kind of didn't take the time to do it right. Have you sanded down the resin?Thanks lol.But yeah, I sanded down any rough spots.
