Posted June 17, 201115 yr I'm about to upgrade my subwoofer wire to 8 ga. from 14 ga. I think I know its real real small, but anyway when upgrading so I need to run the 8 ga. to connect the voicecoils also? I know I have to run the wire from the subs to amp but not sure about the voicecoils
June 17, 201115 yr In order to have the same power transfer throughout the circuit you'll need to change all the wire to 8 gauge.
June 17, 201115 yr It won't make a bit of difference, you have 100+ feet of solid strand 14 gauge in your voice coil.
June 17, 201115 yr 8 gauge is overkill imo. 12-10 gauge should be more than adequate for your needs.^^^ This
June 17, 201115 yr Author Overkill my foot i burnt the lil 14 ga. again so I have to upgrade it to bigger wire before I be buying wire every month.
June 17, 201115 yr Author It won't make a bit of difference, you have 100+ feet of solid strand 14 gauge in your voice coil.So I can keep the 14 ga. On the voicecoils?
June 17, 201115 yr Author If that is the case, please list your entire installation specifications.Two sundown z 15's at 1 ohm (soon to be .5) with a saz-3500 a 270 amp alt. with two deka 8a31's in the back.
June 18, 201115 yr A guy on youtube was running 8 gauge and said most of the wire wouldnt go in all the way. He metered like 149.9 i think. Then switched to 10 gauge and had a better fit on the terminals and metered 150.1 i think. But he gained db.
