Posted June 20, 201115 yr which battery would work for a 1995 camaro im putting my saz 1500 in it i need a battery i can run the car and system off of. i am going with a higher amp alternator also. thanks in advance
June 23, 201115 yr D3400 with 551 Ibar kit or 555 Ibar kit. Depending on the way you are running your set up and the alt you may want to add another smaller battery to the back.
