Posted June 20, 201115 yr hey guyz..... got a question. i had planned on running 4 awg from the battery terminal down to the fuse and then on the other end of the fuse continue with 4 awg and then put a distribution block. then run 4 awg to the other amps from the block. is this ok? or no? running 4 amps, all the same gauge wire
June 20, 201115 yr kinda think you should be running 1/0 awg wiring from the battery terminal to the distro block...
June 20, 201115 yr Author kinda think you should be running 1/0 awg wiring from the battery terminal to the distro block...thanks for replying man. so i should run 0 from the battery to the block and then the 4 awg to the amps. would that work?
June 20, 201115 yr Win your using a D-Block, you never go from the same size to the same size, or go from the same size to a bigger size. Example, if you were to use 4 gauge before the D-Block, then you would have to use anything smaller than 4 gauge after the D-Block. So lets say you wanted to power two amps for yous mids/highs, and they take 4 gauge wiring. You would use 2 gauge, 1 gauge, or 1/0 gauge etc etc... I hope this makes sense. Edited June 20, 201115 yr by Sencheezy
June 20, 201115 yr kinda think you should be running 1/0 awg wiring from the battery terminal to the distro block...thanks for replying man. so i should run 0 from the battery to the block and then the 4 awg to the amps. would that work?Yes sir it would work, its what im currently doing with my system now.
June 20, 201115 yr Author kinda think you should be running 1/0 awg wiring from the battery terminal to the distro block...thanks for replying man. so i should run 0 from the battery to the block and then the 4 awg to the amps. would that work?Yes sir it would work, its what im currently doing with my system now.cool, thanks everybody
