Posted June 28, 201114 yr hey whats up guys, ok so im deciding on ordering an alt soon because im going to bump up to 2k watts and wont happen on a stock 70a alt. so my question is mostly for rob or kyle. If i were to order your biggest alt for an 05 civic which is the 180hp does it come with everything i need to install it and get it running? Iv seen some people having to get brackets ordered for their trucks and cars but will this be my case? I have no idea what i will need or wont need so any info on this would really help my decision. If it doesnt come with everything i need to get it running then what will i need? Thanks guys
June 29, 201114 yr Author does anybody know what the alternator purchase comes with or doesnt come with?
June 29, 201114 yr hey whats up guys, ok so im deciding on ordering an alt soon because im going to bump up to 2k watts and wont happen on a stock 70a alt. so my question is mostly for rob or kyle. If i were to order your biggest alt for an 05 civic which is the 180hp does it come with everything i need to install it and get it running? Iv seen some people having to get brackets ordered for their trucks and cars but will this be my case? I have no idea what i will need or wont need so any info on this would really help my decision. If it doesnt come with everything i need to get it running then what will i need? Thanks guysOn this one, yes it does. The housing we use on this one doesn't require a bracket nor an adapter harness. We are currently out of these for another ~10 days or so however. We changed this alt up a little bit from what the old one was as well and the new version runs pretty close to 200, but just has amazing, amazing idle output for it's size. At any speed below say 2700 alternator RPM's, it will out charge everything we build but the 2270XP and SP.. I *may* make an XP for this, but it will be a few months down the road, but unless your running like 2500+w, a 180 and a GOOD battery is plenty.. You have to remember, you have 70 amps stock, your increase in headroom above stock is the same as putting a 250 amp alt in a Tahoe (145 stock)..
July 1, 201114 yr Author Wow that sounds great lol. So when do you think you will have some and ready to ship? Im not in any hurry cuz i need to wait for my next check was just curious because if its a lil later it might just be a good idea to wait for the xp for the honda civic . Id be running close to 2500 watts. got a aq2200 that will be at 1ohm and an alpine pdx f4 thats 100wrms x 4 @ 2-4 ohms
