Posted July 12, 201114 yr i want to get 2 zcon 18 to put in my expedition would like to know box specs and port size. also anyone who runs ssa subs how do you like them compared to the other brands of subs out there. i ve been out of car audio for a while and dont want a cookie cutter system every shop here has all the big names kicker. orion rockford memphis and all are good but i want different.
July 12, 201114 yr Welcome .... Read through the Tech Section under the SSA Banner and all info should be there.I have a DCON 10" and in a ported enclosure it has great output and excellent sq imo. SSA sub woofers are SQ first but they broke the mold with the new ZCON!
July 12, 201114 yr Author Welcome .... Read through the Tech Section under the SSA Banner and all info should be there.I have a DCON 10" and in a ported enclosure it has great output and excellent sq imo. SSA sub woofers are SQ first but they broke the mold with the new ZCON!ok cool thanks bro
July 12, 201114 yr As a proud owner of two zcons I would have to say best buy for my audio addiction. The amount of output they have while keeping the sound quality Ssa is known for
July 12, 201114 yr Admin I have not finished the specific box specs for the Zcon's yet. Once I do, we will get our designer on them and have designs posted up just like our other drivers have.
July 12, 201114 yr Author As a proud owner of two zcons I would have to say best buy for my audio addiction. The amount of output they have while keeping the sound quality Ssa is known forthats great to here what size zcons do you have if ya dont mind me askin
July 12, 201114 yr Author I have not finished the specific box specs for the Zcon's yet. Once I do, we will get our designer on them and have designs posted up just like our other drivers have.sweet sounds good and i most say from seeing the vids there an awsome sub nice work ssa guys
July 12, 201114 yr Admin These are the unofficial specs for the Zcon enclosures. I was not happy with what I was seeing with my initial specs on the 18, so I am still messing around with it some. Also, the optimal specs are not a must, people are so hung up on building the optimal specs and those who are limited space wise are scared off. The optimal box sizing is more for greater efficiency and slightly flatter response, IF YOU HAVE THE SPACE. If not, the standard designs still give awesome performance. For example, the Zcon 12 in a 2.0 @ 27hz box I have, is just bonkers. So people don't need to absolutely go up to 3 cubes, as 2 can be plenty. Box sizing speaker to speaker, the Zcon leans a little smaller then the Xcon, as they are quite different subs. There will be no sealed enclosure specs for the Zcon.Zcon 12:Ported: 1.75-2.5ft^3 @ 29-34hzPorted: 2.5-3.25ft^3 @ 29-34hz optimalZcon 15:Ported: 2.75-3.25ft^3 @ 29-34hzPorted: 4.0-5.0ft^3 @ 29-34hz optimalZcon 18:Ported: 5.75-7.0ft^3 @ 29-34hzPorted: 7.0-8.0ft^3 @ 29-34hz optimal
July 12, 201114 yr The Zcons are the best sounding balls out loud subs I have ever herd. On another level, IMO.Others may disagree and no I have not herd all of them, , but I would have to hear it for myself to believe it.
July 12, 201114 yr Author These are the unofficial specs for the Zcon enclosures. I was not happy with what I was seeing with my initial specs on the 18, so I am still messing around with it some. Also, the optimal specs are not a must, people are so hung up on building the optimal specs and those who are limited space wise are scared off. The optimal box sizing is more for greater efficiency and slightly flatter response, IF YOU HAVE THE SPACE. If not, the standard designs still give awesome performance. For example, the Zcon 12 in a 2.0 @ 27hz box I have, is just bonkers. So people don't need to absolutely go up to 3 cubes, as 2 can be plenty. Box sizing speaker to speaker, the Zcon leans a little smaller then the Xcon, as they are quite different subs. There will be no sealed enclosure specs for the Zcon.Zcon 12:Ported: 1.75-2.5ft^3 @ 29-34hzPorted: 2.5-3.25ft^3 @ 29-34hz optimalZcon 15:Ported: 2.75-3.25ft^3 @ 29-34hzPorted: 4.0-5.0ft^3 @ 29-34hz optimalZcon 18:Ported: 5.75-7.0ft^3 @ 29-34hzPorted: 7.0-8.0ft^3 @ 29-34hz optimalsounds good how much port area will they need and how long will it need to be
July 13, 201114 yr Admin These are the unofficial specs for the Zcon enclosures. I was not happy with what I was seeing with my initial specs on the 18, so I am still messing around with it some. Also, the optimal specs are not a must, people are so hung up on building the optimal specs and those who are limited space wise are scared off. The optimal box sizing is more for greater efficiency and slightly flatter response, IF YOU HAVE THE SPACE. If not, the standard designs still give awesome performance. For example, the Zcon 12 in a 2.0 @ 27hz box I have, is just bonkers. So people don't need to absolutely go up to 3 cubes, as 2 can be plenty. Box sizing speaker to speaker, the Zcon leans a little smaller then the Xcon, as they are quite different subs. There will be no sealed enclosure specs for the Zcon.Zcon 12:Ported: 1.75-2.5ft^3 @ 29-34hzPorted: 2.5-3.25ft^3 @ 29-34hz optimalZcon 15:Ported: 2.75-3.25ft^3 @ 29-34hzPorted: 4.0-5.0ft^3 @ 29-34hz optimalZcon 18:Ported: 5.75-7.0ft^3 @ 29-34hzPorted: 7.0-8.0ft^3 @ 29-34hz optimalsounds good how much port area will they need and how long will it need to beWe will have full 3D box designs posted up soon.
July 13, 201114 yr Author whats the max rms you guys rec for each driver i plain one runnin sundown sax 2500ds on each one can the hold more if needed
July 13, 201114 yr Admin We do not rate MAX wattage. That amp is fine, just sent the gains properly and listen to make sure you are not over driving the sub woofer or over heating the coils.
July 13, 201114 yr Author We do not rate MAX wattage. That amp is fine, just sent the gains properly and listen to make sure you are not over driving the sub woofer or over heating the coils.thats cool i understand what ur saying im an old school car audio guy been doing this for over 15 years now just been out of the loop for the last 3
July 13, 201114 yr The Zcon product page just got a fresh overhaul.http://www.soundsolutionsaudio.com/index.php/product-information/zcon.htmlWhole store is really looking great guys!Nice job on the makeover.
July 13, 201114 yr Admin Mark found a new table system, and I think it looks much more professional, so we ran through it last night to get it knocked out. Dcon 15 enclosure specs were hammered out last night too.
July 13, 201114 yr Admin The Zcon product page just got a fresh overhaul.http://www.soundsolutionsaudio.com/index.php/product-information/zcon.htmlWhole store is really looking great guys!Nice job on the makeover.Thanks! It's a never ending process...
