Posted July 29, 201114 yr Would there be a big difference in the output if i go 5ft^3 sealed ,vs ported, so i can fit it in my trunk? Has anyone heard an xcon 18 sealed before and how loud can it get sealed?
July 29, 201114 yr Ported would be wayyy louder maybe! But with the correct airspace. But do xcons work well in sealed enclosures??
July 29, 201114 yr umm... 15" Xcon here sealed... running 500w MAX.... and HOLYSHYTLOUD !!! I vibrate like crazy... How loud do you want it? You could put closer to "rated" wattage and be alot louder ... I'm running on low and it is great!!! :fing34:
July 29, 201114 yr Admin Personally, I love the Xcon in larger sealed enclosures. The 12 sealed in 1.75 was awesome. With the slightly higher Qts of the 18, it is an excellent option for sealed.
July 29, 201114 yr it is amazing.... only problem is I now have NEWER rattles in the trunk that I didn't have with the Icon ported.... FML!! Looks like I'll be inside my trunk once again chasing down the rattles while my friend bumps the system.... YAY!!
July 29, 201114 yr Author Personally, I love the Xcon in larger sealed enclosures. The 12 sealed in 1.75 was awesome. With the slightly higher Qts of the 18, it is an excellent option for sealed.I have an 18" Xcon and realized i can't fit it ported, and I was thinking about putting it in ab5.5 cubicft box and I wanting to know what would be better for spl, a Xcon 15" ported or an 18" sealed in 5cubes, like what would be louder?
July 29, 201114 yr Admin Personally, I love the Xcon in larger sealed enclosures. The 12 sealed in 1.75 was awesome. With the slightly higher Qts of the 18, it is an excellent option for sealed.I have an 18" Xcon and realized i can't fit it ported, and I was thinking about putting it in ab5.5 cubicft box and I wanting to know what would be better for spl, a Xcon 15" ported or an 18" sealed in 5cubes, like what would be louder?It will be close, but for daily driving, the 18 sealed will still be a TON of output.
July 31, 201114 yr Author Personally, I love the Xcon in larger sealed enclosures. The 12 sealed in 1.75 was awesome. With the slightly higher Qts of the 18, it is an excellent option for sealed.I have an 18" Xcon and realized i can't fit it ported, and I was thinking about putting it in ab5.5 cubicft box and I wanting to know what would be better for spl, a Xcon 15" ported or an 18" sealed in 5cubes, like what would be louder?It will be close, but for daily driving, the 18 sealed will still be a TON of output.Is 87.92in^2 enough port area for an xcon 18 in a 6.14ft^3 box? (the port would be external) If not whats is the minimum port area required?
July 31, 201114 yr Admin Personally, I love the Xcon in larger sealed enclosures. The 12 sealed in 1.75 was awesome. With the slightly higher Qts of the 18, it is an excellent option for sealed.I have an 18" Xcon and realized i can't fit it ported, and I was thinking about putting it in ab5.5 cubicft box and I wanting to know what would be better for spl, a Xcon 15" ported or an 18" sealed in 5cubes, like what would be louder?It will be close, but for daily driving, the 18 sealed will still be a TON of output.Is 87.92in^2 enough port area for an xcon 18 in a 6.14ft^3 box? (the port would be external) If not whats is the minimum port area required?That is close, but still on the small side.
July 31, 201114 yr Personally, I love the Xcon in larger sealed enclosures. The 12 sealed in 1.75 was awesome. With the slightly higher Qts of the 18, it is an excellent option for sealed.I have an 18" Xcon and realized i can't fit it ported, and I was thinking about putting it in ab5.5 cubicft box and I wanting to know what would be better for spl, a Xcon 15" ported or an 18" sealed in 5cubes, like what would be louder?It will be close, but for daily driving, the 18 sealed will still be a TON of output.Is 87.92in^2 enough port area for an xcon 18 in a 6.14ft^3 box? (the port would be external) If not whats is the minimum port area required?It is quite small, due to the displacement capabilities of the XCON I recommend a minamum of 1102 inches of port area.
August 1, 201114 yr Author This thing is a F@#$%^G BEAST barley turned up, i have to get another alternator my voltage drops to 11, then i can see what it can really doits 4.66ft^3 after displacements, & i want to build a ported box but the ports have to 30 inches long external that will come later if i can fit itim going to upload some videos later too Edited August 1, 201114 yr by marq7890
August 1, 201114 yr holy shit that is a tight fit man... looks god though.. def want some videos...!!!
August 1, 201114 yr Admin Heck of a squeeze. Not sure if you even tried to go ported it would have enough room to breathe. Let it run sealed, that is my vote.
August 1, 201114 yr I gotta tell you... sealed is giving me more shakes and rattles everyday... I tried doing sub up and man was it louder and stronger but holy hell I need to have everything screwed down on the rear deck and roof liner in the back is coming off now... lol
August 2, 201114 yr Author Got to love a video like this with a SEALED sub woofer. right now its wired at 2ohm and my amp is rated at 1200watt at 2ohm and im scared to turn it up my voltage drops below 11 Edited August 2, 201114 yr by marq7890
October 23, 201114 yr Got to love a video like this with a SEALED sub woofer. right now its wired at 2ohm and my amp is rated at 1200watt at 2ohm and im scared to turn it up my voltage drops below 11Do you have any new pics of the setup?? Your avatar looks pretty sweet!
October 23, 201114 yr Author Got to love a video like this with a SEALED sub woofer. right now its wired at 2ohm and my amp is rated at 1200watt at 2ohm and im scared to turn it up my voltage drops below 11Do you have any new pics of the setup?? Your avatar looks pretty sweet!
