Posted July 30, 201115 yr Hi ive been running my 15" Q in a 2.2 cubed box for over a year now with a SAZ-1000d mono amp, and its been awesome!now making the boxes isnt a problem as i designed and built my last one!but im looking for something different and maybe a bit louder without changing much and spending alot! so i thought ill port it!i looked at the cut sheet in this section for the 15 ported in here but its slightly too big at 3.8 cubes and was wondering if anyone could adjust it to maybe 3.2-3.4 cubes for me :/ being a complete noob with port sizes and stuff!max height is about 17 1/2" really!Thanks Pez! sorry for being a pain
July 30, 201115 yr http://www.reaudio.com/LPort_Box_Calc.phpThis is the calculator I use to tune my boxes, and it's worked well so far. But I have heard from people it's off with the tuning sometimes. But type in these options, from top to bottom.Box Width: 27"Box Height: 17.5"Box Top Depth: 17"Box Bottom Depth: 17"Wood Thickness: 0.75"Square Port Width: 2.25"Square Port Length 2: 12"Good luck Remember bracing and double baffle! Edited July 30, 201115 yr by Freshh
July 30, 201115 yr I've never had a problem with it, but I've only built three boxes with it. Which do you prefer?
July 31, 201114 yr Author Ah cool, this has helped a lot! im sure it will be fine for what i need brace the "L" and double baffle i believe meaning two front sheets yes? ill have a play with the sizes to suit my boot!
July 31, 201114 yr You're correct, double baffle means that the side that the subwoofer is mounted on is two layers thick.
August 1, 201114 yr Author Box Width: 35"Box Height: 17"Box Top Depth: 15"Box Bottom Depth: 15"Wood Thickness: 0.75"Square Port Width: 2.5"Square Port Length 2: 12"I've come up with the solution atm, as i have measured my boot in more detail! as its a normal hatch back astra the rear seats are at an angle but this calc doesnt really account for this as it would be showing the port facing into the seat :/ hope you followanyone quickly run that through and see any problems?Thanks a lot! pez
August 1, 201114 yr Author Ill carpet it to the best of my ability again lol! or might wait untill i re trim all my interior somewhere and ask a company to do it as i like things done properly or at least look it lol ok mate so box should be fine? i can adjust its mainyl the depth ive got to work with, shame the depth one and depth 2 dont work the way i need them too! Edited August 1, 201114 yr by Pezzaboi
August 1, 201114 yr I don't trust the RE calc either. When I figure out tuning for an enclosure I use winisd and compare it with the one on here, and it's 99.9% of the time within like 1/4" of eachother lol. If you use the calc on carstereo.com and you wanna do a slot port, keep slot port set to "no". For some reason it adds some random value to it, possibly for end correction, I don't know.
August 1, 201114 yr Author will some one with little experience be able to notice that much? im used to running my Q sealed and its amazing! ill keep that enclosure also in case!but i know a lot of people on here are awesome and get really technical but i dont know how much of a difference that would really make :S ? ill try another calc anyway
August 1, 201114 yr I don't trust the RE calc either. When I figure out tuning for an enclosure I use winisd and compare it with the one on here, and it's 99.9% of the time within like 1/4" of eachother lol. If you use the calc on carstereo.com and you wanna do a slot port, keep slot port set to "no". For some reason it adds some random value to it, possibly for end correction, I don't know.thanks for that link... the port area minimum calculation is awesome...
