August 30, 201115 yr Which ones did you get? Dual 4ohm or Dual 2ohm?\dual 1'sWhy 32Hz?just a guess. and the other boxes i built at 32hz sounded good. i love the lowes;) hahaLet's build something together?
August 30, 201115 yr Author Which ones did you get? Dual 4ohm or Dual 2ohm?\dual 1'sWhy 32Hz?just a guess. and the other boxes i built at 32hz sounded good. i love the lowes;) hahaLet's build something together?and hows that gonna work?haha
August 30, 201115 yr Author How tall is the port, port area is just height x width19.50x3 so 58.5????? the box is a total of 31" high and im using .75 mdf so 21-1.5 (.75x2) thats where i got 19.50 from for those wondering.
August 30, 201115 yr U sure they are dual 1's? i was looking for the t/s parameters on them and all i found was the 07 d4 and d2 versions
August 30, 201115 yr Aero Ports are easy to tune! Take up less internal volume and you can get away with less port area due to the flares.Go with what your comfortable with when it comes to calculating.
August 30, 201115 yr U sure they are dual 1's? i was looking for the t/s parameters on them and all i found was the 07 d4 and d2 versions2007 is not the only year Kicker Solo X's were made, here ya go:Dual 1 ohm X's
August 31, 201115 yr Author U sure they are dual 1's? i was looking for the t/s parameters on them and all i found was the 07 d4 and d2 versions2007 is not the only year Kicker Solo X's were made, here ya go:Dual 1 ohm X'sthanks for clearing that up for me jay-cee
