Posted September 3, 201115 yr The site now says 1500watt rms, is this a miss type? Its only for the 10-15
September 3, 201115 yr Author Shit, I dont know a lot about all the specifics of this. Will I still be able to run a sundown SAZ-1500v with a new 15? Will i just have to wire it differently or should I just look into a different sub.
September 5, 201115 yr Should be fine man. I have a sundown 1500 on my old Q. 1500 watts is the max continous power that it can handle, there is no minimum. On a side note, why is the 18" "limited" to 1kw? Edited September 5, 201115 yr by beandip
September 6, 201115 yr when did they get re rated to 1500w? i bought a 12" Q a month ago and its coming today.does mine fall into that group thats rated at 1500w? or is it still the ones rated at 1kw thanks
September 6, 201115 yr They haven't changed again in the last month, they probably just re-rated the new version.
September 6, 201115 yr Just want to add that not all of the bl's have been updated to 1500 watts as well, may want to update that as soon as possible before more questions like this arise
