Hey guyz I'm about to order an saz 1500v2 could I strap another saz 1500 that's a v1? Is that ok or will they go kaboom? Thanks
You should definately find out, i had an issue when i first strapped mine but they were both brand new and i had a new one within a week and a half. Also when you do strap them make sure you have a good electrical system, they need alot of juice but man do they bang. Good luck.
Whats so different about them that makes them non strapable?
They are not identical.
Two different circuit boards and circuit design.
V.1 can be had used pretty reasonable. Actually I think Sundown has some listed in the "Yard Sale" thread.
I have a v1 1500d I'd like to get rid of. PM me if you're interested.
Thanks y'all I just may be picking up inkfx's v1 and adding another later
I strapped 1 V.1 and a V.2 with no issues... or at least none that I knew of, but to be honest I was only like .5db louder with two strapped at 2ohm than one at 1/2 ohm.
The latest saz1500d v2 is like 1.5" shorter overall.
Yours look like their the same length, so both v1 but just different revisions?
That may just be the angle they're at, Stefan. I wouldn't strap the 2. Even if it does "work", it's not risk I'd be willing to take.. And i trust 98GMC ;)
I think you are correct the one on the right is revision B with more cooling fins and the left is the OG. My mistake!!
V.2 dosent have fuses on the side either.
Good call, I forgot about that.
