As you may know these trunks are huge but shaped stupid wierd.... Just counting the center portion of the trunk, internally i have 8.11 cubes possibly more. I think if i were to remove or alter the carpet padding in the trunk i could gain a little more space. No plans on competing, just having some fun with a rediculous street beater. Plan to run 5- 7k, 3 d3100s, d2400 up front. if i could possibly get a dual alt setup, which if i can getting amps at that is not an issue. All i listen to is rap. any other factors i may be missing, feel free to chime in. I've had no beat since 09.
remember the port and driver displacement.
Right 8 of em comes up to about a cube, which i probaly could make up for that measurment was low balled a little, just counting the center portion which leaves the two sides at just over a cube on each side for a total of 10.13 cubes internal space, minus speaker displacement gives me 9.17 internal including double baffle... Could have the box a couple inches higher but since no rear folding seat, need some elbow room so they can breathe. Give or take i can go bigger. Was thinking 2 separate boxes only way to fit em in there. Will be using aeros or making my own flared sonotube per box... Which i have no idea how to calculate round ports, but will learn... tuned to 32 hz
Just remeasured and my net dimensions including double baffle are 39.5 wide, 22.75 high, 23.5 deep. RF's site says it coming out to 12.22 cubes....
shiiit. i think mine was 8 cubes outside.. and inside was just shy of 6 after all the bells and whistles
and my shit was pretty snug i still get asked all the time on youtube if i was choking my subs " cause it looks like your choking them if i had a car i would blah blah blah".. sorry about that rant.\
Damn that is a tight fit... 2 15s or 4 12s was my original plan, which after seeing this ported is not gonna work... Would 8 sa10s sealed get me louder than these two options... I would think 4 sa 12s on 3.5k would be my best option... Thinkin 6 cubes at 32 hz 90-100 sq in of port
