Posted September 15, 201114 yr Some production shots from the factory before they were loaded up :----------SD-2 10"----------SD-2 12"----------You will note these have 16 vent holes in the frame vs. 12 on the prototypes and the surround is stitched on -- the surround material is also an upgraded material. Otherwise the cone / spider / frame are equal to the SA line. The motor and coil shrank down a bit -- so you can think of the SD-2 like a "mini-SA" line.
September 15, 201114 yr Any price ranges these will be in? A 10" would be nice to experiment enclosures with this.
