Posted September 20, 201115 yr I installed my Sundown SAX 1200d got it tuned the way I like it then broke my RCA's inside the amp's input terminals... I hooked my AQ1200d back up(I had some tsunami RCA's I never used) so I have to send my amp back to DB-r to get the RCA terminals fixed. Edited September 20, 201115 yr by Crich03
September 20, 201115 yr i donno about the soldier idea.. but i would take it apart and see if i can push it out...HTF do you do somthing like that?? unless you didnt mount the amp.
September 20, 201115 yr i donno about the soldier idea.. but i would take it apart and see if i can push it out...HTF do you do somthing like that?? unless you didnt mount the amp.It was a pita but I did it after a shop broke the RCA pins inside my amp inputs. On my Alpine you couldn't push them out from the inside. Edited September 20, 201115 yr by ricksi30
September 20, 201115 yr Author I had the amp half mounted because I was in the middle of installing it(user error lol) I learned my lesson though
September 20, 201115 yr Author i donno about the soldier idea.. but i would take it apart and see if i can push it out...HTF do you do somthing like that?? unless you didnt mount the amp.Good idea I will take it apart and try that
September 20, 201115 yr Maybe try this http://www.instructables.com/community/Removing-Broken-Pin-from-an-RCA-Jack/
September 20, 201115 yr Author Maybe try this http://www.instructables.com/community/Removing-Broken-Pin-from-an-RCA-Jack/ I will try this thanks
September 20, 201115 yr It was a pita but I did it after a shop broke the RCA pins inside my amp inputs. On my Alpine you couldn't push them out from the inside.What the hell kinda hacks work at that shop that they would break the pins off rca jacks?
September 20, 201115 yr lol, you would be very surprised at who can get hired at these shops.And I can't. Ain't that a bish?
September 20, 201115 yr I don't get it either, I tried for years to get hired at EBgames and gamestop and shit, they never did hire me and instead always had some dumbasses who didn't know shit about games working in them. I guess a lifetime of playing/collecting/researching all sorts of games from Pong-present isn't acceptable. I had more games than the store and still wasn't good enough. I think it's all about who you know in most cases.
September 20, 201115 yr lol, you would be very surprised at who can get hired at these shops.On top of doing it they decided to use a splitter on the remaining channel and not tell me. My front stage was running off of a single channel on a two channel amp. The worst part about this was that it was all new equiptment that I bought from THEM. They broke my A pillar, used 8 gauge for a 1000 watt amp. I had to go to work after I picked up the car, so I couldn't bring it back until the next day. They denied it all and said I must have done it after I left. That was when I was 16 and the reason I learned how to do things myself.
September 20, 201115 yr lol, you would be very surprised at who can get hired at these shops.On top of doing it they decided to use a splitter on the remaining channel and not tell me. My front stage was running off of a single channel on a two channel amp. The worst part about this was that it was all new equiptment that I bought from THEM. They broke my A pillar, used 8 gauge for a 1000 watt amp. I had to go to work after I picked up the car, so I couldn't bring it back until the next day. They denied it all and said I must have done it after I left. That was when I was 16 and the reason I learned how to do things myself.I know most people change amp or headunit settings after they leave a shop but honestly who would change out amp wire or speakers in the A-pillars, if that was the case then why even bring it to the shop and let them install it in the first place. Fucking morons I swear
September 20, 201115 yr It really sucked at the time, but looking back it was a lesson learned and Idk if I'd have half the knowledge about car audio that I do had it not happened. Edited September 20, 201115 yr by ricksi30
September 20, 201115 yr It really sucked at the time, but looking back it was a lesson learned and Idk if I'd have half the knowledge about car audio that I do had it not happened.Trust me thats how I got into car audio myself, let some clowns at Best Buy do a radio and system install to only have me tweaking it every so often cause of there stupidity.
September 21, 201114 yr Author I'm learning everyday through making dumb mistakes like this... Lucky for me I had another amp in my closet and another set of RCA's or I would be without bass right now.
October 1, 201114 yr Author To add closure to this post I fixed the SAX 1200d today and it's beating up my BL again
October 1, 201114 yr To add closure to this post I fixed the SAX 1200d today and it's beating up my BL againAwesome! What did you do?
October 1, 201114 yr To add closure to this post I fixed the SAX 1200d today and it's beating up my BL againAwesome! What did you do?X2 always interested in finding out how to fix/figure out problems.
October 1, 201114 yr Author To add closure to this post I fixed the SAX 1200d today and it's beating up my BL againI used a small screw and screwdriver... I screwed the screw into the soft part inside of the metal RCA piece and pulled it out.Awesome! What did you do?
October 1, 201114 yr Author I can't take credit for figuring it out. I got the solution from db-r, then really felt like an idiot cause it made sense lol
