I have a guy going to be building a sound quality system with alot of equipment he has had for years (he has more equipment then alot of shops---his last count 2.5 years ago was 68 amps, 45 subs, 42 sets of components, 27 coax sets, 84 decks, 7 different eqs, 8 diff crossovers, and more) he has added to this rapidly since. he also has a wall doing 159.4 peak outlaw, blow thru 154.3 outlaw, trunk doing 151.8, and trunk doing 147.6. these are all daily systems too! the guy is a little crazy! now he wants to do a sq system and has everything (dont no exact equipment but using 2 31 band crossfire eqs and 2 crossfire 4 way crossover-old school and audio control center channel driver and audio control 8v line drivers). he is using seperate amps for everything and will be using a pair of sundown e8v1 in his kick panels each running off a 500 watt amp (1ohm stable running at 2 ohm equaling 250 w rms each sub). the e8s will be used as more of a mid/front stage bass. he feels this may add a little difference overall from the norm. what do you guys think would be a good size for kick pod enclosures for these off 250 rms each?
Why not steer him towards the new NEO 8"? :peepwall:
Edited by 98GMC
Why not steer him towards the new NEO 8"? The E8v1 was designed as a subwoofer. A subwoofer is not designed to play up to 1K-2500hz.
lol............. 1k-2500hz??? that aint a midbass range. you might wanna check on that. hes talking about the 50-150hz range i believe.
:roflmao:
My bad! To damn early, need my morning caffine!
Im no sq expert but one thing I've known / learned is keeping it simple, as Sean said.
Throwing too much shit together just because you have it is a bad idea.
If you keep the crossover at 200-250hz, or lower, I'm sure it will be fine. I'm not sure how high those e8's can play, but you don't want a dedicated midbass playing much higher than that anyways.
if you know Jamie Basset out of Havre MT formally from Ipswitch SD then you know he has a sh!t ton of equipment and randomly throws stuff together and is always louder then he should be. he showed up to a show with 6 12s walled, 2 weeks later 4 15s walled, 3 weeks later a trunk system and the next weekend 2 18s walled. This was all in 1 vehicle. The guy is crazy and has a pretty good plan and just need a little with the question at hand. The e8s are for a low end midbass in his front stage. and thanks jacob.
Any ideas other then .2 jacob?
:roflmao:
haha my 18s love around 2000hz!!!!!!!!!!!!!!!!!!! WOOT WOOT!!! and jamie will not buy new equipment
I wouldn't call it a good plan so far. Making it very hard on himself to be successful with his goals if they are truly SQ.
if you knew who i was talking about you would know its a good plan for him
