Posted September 22, 201115 yr Ive been wanting a 6thorder for a while. I wanna try to build one for one of my sundown sa-15s i dont how big to make the chambers or the tuning. I listen to all rap and songs with low bass. Idk what do do someone help me. And what types of wood can i use?
September 22, 201115 yr Honestly I would pay for someone to design it for you. Ram_Designs and Bromo on SSA will help and are very good. If you want to try to design it for yourself:Fourth Order BandpassSixth Order BandpassI would use MDF or Birch wood for the construction. Birch if you want to save weight. MDF if you want to save money. 3/4" either way.
September 22, 201115 yr Ive been wanting a 6thorder for a while. I wanna try to build one for one of my sundown sa-15s i dont how big to make the chambers or the tuning. I listen to all rap and songs with low bass. Idk what do do someone help me. And what types of wood can i use?Do you have the room to do such an enclosure in your vehichle? For just 1 15" subwoofer I would stick to doing a standard 4th order ported enclosure tuned to 30-32hz for your listening tastes.
September 22, 201115 yr Author Lol i had a 7.3 cube box in my trunk before So im hoping i could fit one. Where can i get birch wood and what exactly is it?
September 22, 201115 yr Birch wood is found at home depot or lowes. I don't know what you are asking about what it is? It can be found near all the other wood.
September 22, 201115 yr Author Birch wood is found at home depot or lowes. I don't know what you are asking about what it is? It can be found near all the other wood.Ok. And u ment like what is the specific name for it but that was a dumb question lol
September 22, 201115 yr Just do a standard ported. If you are that far from being in the "know" the end result won't be as good. Trying something new is a horribly stupid reason for doing something unless you plan to do all the design work and are willing to build three+ different enclosures to compare so you can actually learn. Saying that another way, if the try is to learn then carry on. If its to try, then don't.
September 23, 201115 yr Birch wood is ply wood. But you can't get the cheap stuff. It is about $50 a sheet. I might be convinced to do a 6th order design... If you are serious about building it.Duane
January 4, 201214 yr 6th order is more or less a once note strong box no? sorry to bring up an old topic.
January 4, 201214 yr You should just start a new topic. It can be if you want, or don't do it right. They are very picky about getting everything correct. But they can have a flat response if done well.
