Posted January 22, 200620 yr ok guys here is the deal i have 4 us amps i am going to be installing in my jeep and i need to know what size fuse to put on themi have (1) 4300X(1) 4260(2) PT-800what i would like is the fuse ratings for all of them and a suggestion of what size fuse i should use on my power wire to all 4 amps.i am pretty sure the fuse rating on the 4300X is 60AmpsI plan on just adding all the fuse ratings up and getting a fuse about that size.thanks -=ScottY=-
January 22, 200620 yr http://www.usamps.com/old_site/site_index.htmthats the old site, the only info i could find.
January 22, 200620 yr Author http://www.usamps.com/old_site/site_index.htmthats the old site, the only info i could find.<{POST_SNAPBACK}>yeah unfortunitley i am at work and whenever i try to load the .pdf wiht the specs for the PT-800 (on the 2001 sheet) it locks up the page.LAMEthanks for the help though guys.-=ScottY=-
February 6, 200619 yr I am running 2 IS2150s, what fuse should I be using? I put a 60A one in for now, I hope it's the right one.
