I am ready to buy enclosure design software, I want all the features available. I am thinking of buying Term-Pak. With Term-Pak I can later purchase Term-LAB meter as well. Term-Pak includes Term-Pro and Term-CAD 3D. Is this the best that is available? It looks like it was written in the early 90's.
"best" is relative. Either way its the operator that makes the difference. Why not just stick with Win ISD?
Thanks for replying M5.
I do have WinISD. I have spent a couple hours with it. What I am really interested in is being able to plot SPL with a given power (I know a vehicle's cabin dynamics change that), driver x-max with given power and port velocity. I would also like to be able to design enclosures with cut sheets the easy way with a program. From my limited experience with WinISD I have not been able to do this. WinISD does basic plotting, I am ready for more.
I know Trevor (Thumpper) at Pound That Sound uses that program and loves it.
I saw his work. Good to know it works for him.
Look into leap.
Wow. Leap EnclosureShop is $795 :ehh:
Winisd does everything but cut sheets. those are better done by hand in general anyways
I have not been able to view excursion using WinISD. Am I missing something?
Not sure what version of WinISD you are using, but here it is in mine:
FWIW, I also use Unibox a lot. It's GUI is terrible as it's simply an Excel spreadsheet, but I like it a little better than WinISD for a little bit quicker looks at things (driver input, for example, IMO is a lot easier in Unibox). From what I've heard it can also be more accurate than WinISD but I've never taken the time to compare them.
Agree completely, but if you can't find excursion in WinISD then using unibox will be impossible.
I am using Version 0.44
I will look into Unibox
touche.
I clearly need to invest more time with WinISD
Look for .70 It is the latest.
