running at 2ohms seems to be the smarter way here, cuz i know from experience its stressful always thinking you might blow your $1000 equipment if you turn it up a tad bit too much, i like to do rated or slightly lower so i dont worry so much about over driving my stuff and having nothing. and its exciting knowing your amp is only at half power and can always add another sub while keeping the same amp for it :)
  • Replies 54
  • Views 8.7k
  • I have my 18s temporarily wired up in a less than optimal enclosure right now (~11.75 cubes tuned to 40hz) wired to 2.8 nominal on an SAZ3500D just to try everything out and evaluate the electrical a
  • You should spend some money on glasses. The ones in your avatar are ready to be replaced. It'll seriously help with the ladies.
  • ShagggDiesel
    ShagggDiesel
    or just get one amp that is equivalent to the power of two amps, save money, and trouble.
yes it is haha.
that AQ3500 will put out 2600wrms@2ohms
so even at 2 ohm its a little much for the zcon?
No its not, music is dynamic. Stop worrying about how much power your going to give the driver, the box will determine that more than you or anyone on this forum. 2 ohms on that amp will be fine.
