Posted October 23, 201115 yr I just recently bought 2 FI BL 12's fully loaded with 4 inch voice coils. I have 2 questions for the forum if you guys can please help with me. First i am running a Rockford Fosgate 2500-1bdcp on the and since the subs are dual 1 ohm is this enough power for them? Second, the enclosure i had built for them is 4.23 cubic feet after everything and tuned to 33 hz. Will they sound good in this enclosure or should i have made it bigger? The amp puts out 3,526 watts total. Thanks in advance.
October 23, 201115 yr Do you mean net when you say "after everything", or is that before you subtract port and wood thickness?
October 23, 201115 yr Author Do you mean net when you say "after everything", or is that before you subtract port and wood thickness?Yes after wood, bracing and everything my net is 4.23 cubic feet.
October 25, 201115 yr I hope so. It seems that these subs need alot of power.why do you say that? Edited October 25, 201115 yr by trod2902
October 25, 201115 yr Author I have no idea about the port area because someone built it for me. It has 2 inch baffle, 1 inch bracing inside and 1 inch all around the outside. The reason i think they need alot of power is because i had a set of 12W7's running on this amp and at half volume you couldnt sit in my SUV. With the FI's in i actually had to adjust the gain up to get the same output.
October 25, 201115 yr 1" all around and a 2" baffle is thick! Thats gonna be nice and strong for sure,
October 26, 201115 yr I have no idea about the port area because someone built it for me. It has 2 inch baffle, 1 inch bracing inside and 1 inch all around the outside. The reason i think they need alot of power is because i had a set of 12W7's running on this amp and at half volume you couldnt sit in my SUV. With the FI's in i actually had to adjust the gain up to get the same output.Not everything else is the same...
October 26, 201115 yr Author I agree!! I think i was more worried about the enclosure being correct air space than anything.
November 3, 201115 yr Bl's are the shit banging on mine for over a year now taking 3500rms like a champ with the 3inch vc
November 6, 201114 yr Author The new enclosure arrived!!! Oh my God these things are so loud and hit so hard. The wait was worth it.
