Posted November 2, 201114 yr I have a chance to pick up a Ultra Linear UL1500X for $50 bucks and was wondering if it was a good amp and price? It would be used to replace my Earthquake PH120.2. to run 2 Earthquake dbx10 10 subs.Here are the specs:1500W Class X Mono Block Amplifier12-17V Power Input0.2-8V RCA Input VoltageFrequency Response 10 Hz - 350 HzShort / Overload / Thermal ProtectionBridgeable with second Class X amplifier24dB Variable Subsonic Filter24dB Variable Low Pass Filter0-18dB Variable Bass BoostRemote Gain Control ModuleRCA Line OutputRMS Power @ 14.4V DC1 x 500W @ 4 Ohm1 x 750W @ 2 Ohm1 x 1000W @ 1 OhmRMS Power @ 17V DC1 x 750W @ 4 Ohm1 x 1000W @ 2 Ohm1 x 1500W @ 1 Ohm Edited November 2, 201114 yr by Robertjr79
November 2, 201114 yr I have a chance to pick up a Ultra Linear UL1500X for $50 bucks and was wondering if it was a good amp and price? It would be used to replace my Earthquake PH120.2. to run 2 Earthquake dbx10 10 subs.Here are the specs:1500W Class X Mono Block Amplifier12-17V Power Input0.2-8V RCA Input VoltageFrequency Response 10 Hz - 350 HzShort / Overload / Thermal ProtectionBridgeable with second Class X amplifier24dB Variable Subsonic Filter24dB Variable Low Pass Filter0-18dB Variable Bass BoostRemote Gain Control ModuleRCA Line OutputRMS Power @ 14.4V DC1 x 500W @ 4 Ohm1 x 750W @ 2 Ohm1 x 1000W @ 1 OhmRMS Power @ 17V DC1 x 750W @ 4 Ohm1 x 1000W @ 2 Ohm1 x 1500W @ 1 OhmI think for 50 dollars you cant go wrong.
November 2, 201114 yr Author Thanks, I know I can't go wrong for $50 but is the amp any good? I never used Ultra brand before and was looking for someone that maybe used this amp before.
November 2, 201114 yr Thanks, I know I can't go wrong for $50 but is the amp any good? I never used Ultra brand before and was looking for someone that maybe used this amp before.Do search on the internet and see what you find.
November 3, 201114 yr Admin Ultra has seemed to have a mixed track record. They came on really hot two years ago, again another one of these better then all others based on some of the hype, but when some people started paying attention and using the products themselves, things changed a little. They had some big traffic on DIYma for a few months, and now there is almost no mention of them anywhere. We almost hosted the Ultra forum here on SSA, but then with the issues some customers had with the owner, right from the get go, we decided not to. From what I remember, supposedly the amps share a lot of bits from an ARC design.
November 4, 201113 yr Author I picked up the UL1500X plugged it in and up in smoke. I hurried up and unplugged it as fast as I could. I took it in the house and took the top cover off and found this.Guess I should of known better that that. Edited November 4, 201113 yr by Robertjr79
November 6, 201113 yr Ultra has seemed to have a mixed track record. They came on really hot two years ago, again another one of these better then all others based on some of the hype, but when some people started paying attention and using the products themselves, things changed a little. They had some big traffic on DIYma for a few months, and now there is almost no mention of them anywhere. We almost hosted the Ultra forum here on SSA, but then with the issues some customers had with the owner, right from the get go, we decided not to. From what I remember, supposedly the amps share a lot of bits from an ARC design.That is a different Ultra.Ultra Linear I believe is another Pyramid-esque brand.
November 6, 201113 yr I have a chance to pick up a Ultra Linear UL1500X for $50 bucks and was wondering if it was a good amp and price? It would be used to replace my Earthquake PH120.2. to run 2 Earthquake dbx10 10 subs.Here are the specs:1500W Class X Mono Block Amplifier12-17V Power Input0.2-8V RCA Input VoltageFrequency Response 10 Hz - 350 HzShort / Overload / Thermal ProtectionBridgeable with second Class X amplifier24dB Variable Subsonic Filter24dB Variable Low Pass Filter0-18dB Variable Bass BoostRemote Gain Control ModuleRCA Line OutputRMS Power @ 14.4V DC1 x 500W @ 4 Ohm1 x 750W @ 2 Ohm1 x 1000W @ 1 OhmRMS Power @ 17V DC1 x 750W @ 4 Ohm1 x 1000W @ 2 Ohm1 x 1500W @ 1 OhmI guess it was not a good amp and price after all.
November 6, 201113 yr Author I have a chance to pick up a Ultra Linear UL1500X for $50 bucks and was wondering if it was a good amp and price? It would be used to replace my Earthquake PH120.2. to run 2 Earthquake dbx10 10 subs.Here are the specs:1500W Class X Mono Block Amplifier12-17V Power Input0.2-8V RCA Input VoltageFrequency Response 10 Hz - 350 HzShort / Overload / Thermal ProtectionBridgeable with second Class X amplifier24dB Variable Subsonic Filter24dB Variable Low Pass Filter0-18dB Variable Bass BoostRemote Gain Control ModuleRCA Line OutputRMS Power @ 14.4V DC1 x 500W @ 4 Ohm1 x 750W @ 2 Ohm1 x 1000W @ 1 OhmRMS Power @ 17V DC1 x 750W @ 4 Ohm1 x 1000W @ 2 Ohm1 x 1500W @ 1 OhmI guess it was not a good amp and price after all.Guess I got what I paid for. lol oh well I have a nice and heavy paper weight now
November 6, 201113 yr Admin Ultra has seemed to have a mixed track record. They came on really hot two years ago, again another one of these better then all others based on some of the hype, but when some people started paying attention and using the products themselves, things changed a little. They had some big traffic on DIYma for a few months, and now there is almost no mention of them anywhere. We almost hosted the Ultra forum here on SSA, but then with the issues some customers had with the owner, right from the get go, we decided not to. From what I remember, supposedly the amps share a lot of bits from an ARC design.That is a different Ultra.Ultra Linear I believe is another Pyramid-esque brand.Ahh yes, sorry. Please disregard my earlier post.
November 6, 201113 yr Ultra has seemed to have a mixed track record. They came on really hot two years ago, again another one of these better then all others based on some of the hype, but when some people started paying attention and using the products themselves, things changed a little. They had some big traffic on DIYma for a few months, and now there is almost no mention of them anywhere. We almost hosted the Ultra forum here on SSA, but then with the issues some customers had with the owner, right from the get go, we decided not to. From what I remember, supposedly the amps share a lot of bits from an ARC design.That is a different Ultra.Ultra Linear I believe is another Pyramid-esque brand.http://www.carreview.com/cat/car-audio/amplifiers/ultralinear/ul1500x/prd_345269_1806crx.aspx
