I am buying a 15 fi q and was thinking about using the alpine pdx m12 because I have the four channel pdx. I want a good amp with real good sq. Anyone have experience with the amp
Then get a class A/B 2ch amp that is capable of 1200w bridged.
someone with a serious answer please
SQ, for a subwoofer amplifier? Won't matter. If you want SQ the front state is where you want to concentrate.
We know he's misusing the term "SQ".
That amplifier will be fine...
do you think a sundown or aq would be better
jsut want to get it right the first time i just got a new car and in my past i had a jbl 1500.1 and i feltlike it was way under rated
You will not hear the difference between either amp as long as their around the same power.
Personally I like the aesthetics of the Sundown Amps.
have you ever dealt wilth or heard the pdx and do you think that the one 15 q be good
The Alpine will more than meet your needs, your install will dictate if it sounds good or not.
you think a 4 cube box at 32hz is my best bet or different size. and thanks for all the input
I have a PDX-M12 and I also have a PDX 1.600 and they seem fine to me. Main reason I went PDX is because of the small footprint and the fact that they can be stacked.
