Posted November 9, 201114 yr Got a small stealth box I'm putting in my car and I need a sub for it. I believe the SA-10 would work,just want to make sure.I also need advice on which amp.Here's the box specs..... .6 cu ft space,sealed. Mounting depth of 8 inches.
November 10, 201114 yr Pick an amp from a company you like, is within your budget and makes the power you want at whatever ohm rating you're playing at.
