November 11, 201115 yr Author Aaron mentioned the same as the old model. Maybe a tad smaller3 cuft ported to 34 hz work?
November 11, 201115 yr Admin I have not gotten the final sizes to Mark, just been a bit behind, hence why the page is not updated yet. But Sean is correct, over all the box sizing will not change too much. The driver displacement is greater and the motor is stronger, so initially it was leaning towards a slightly smaller box. The original Icon was beautiful in larger then average enclosures with 200-1200 watts. The new Icon is a little more aggressive and lost a little bit of efficiency.
November 11, 201115 yr Author I have not gotten the final sizes to Mark, just been a bit behind, hence why the page is not updated yet. But Sean is correct, over all the box sizing will not change too much. The driver displacement is greater and the motor is stronger, so initially it was leaning towards a slightly smaller box. The original Icon was beautiful in larger then average enclosures with 200-1200 watts. The new Icon is a little more aggressive and lost a little bit of efficiency.If I go 4cuft @34hz wil that work?
November 12, 201115 yr Author Also did I miss any info on mounting depth? Any help would be appreciated.depth of the box? 16"
November 12, 201115 yr Also did I miss any info on mounting depth? Any help would be appreciated.depth of the box? 16" I was asking what the mounting depth of the Icon is haha
November 12, 201115 yr Author Also did I miss any info on mounting depth? Any help would be appreciated.depth of the box? 16" I was asking what the mounting depth of the Icon is hahaI dont know for sure on the new ones. .19 displacement. Ask Aarron
November 12, 201114 yr Admin Also did I miss any info on mounting depth? Any help would be appreciated.No real over all change in mounting depth.
November 12, 201114 yr Admin I have not gotten the final sizes to Mark, just been a bit behind, hence why the page is not updated yet. But Sean is correct, over all the box sizing will not change too much. The driver displacement is greater and the motor is stronger, so initially it was leaning towards a slightly smaller box. The original Icon was beautiful in larger then average enclosures with 200-1200 watts. The new Icon is a little more aggressive and lost a little bit of efficiency.If I go 4cuft @34hz wil that work? Yes.
November 12, 201114 yr Author I have not gotten the final sizes to Mark, just been a bit behind, hence why the page is not updated yet. But Sean is correct, over all the box sizing will not change too much. The driver displacement is greater and the motor is stronger, so initially it was leaning towards a slightly smaller box. The original Icon was beautiful in larger then average enclosures with 200-1200 watts. The new Icon is a little more aggressive and lost a little bit of efficiency.If I go 4cuft @34hz wil that work? Yes. Thanks
